I've got an Arduino Uno and two Adafruit VC0706 cameras. I've been following the tutorial and have gotten the cameras partially working.
I am able to get a working video signal from the analog out, and I've gotten the cameras to work with the provided CommTool. However, I cannot get the camera library and sample code to recognize the camera. cam.begin() always gives the message "No camera found?". So I went into the library code and added some extra print statements to see where it is failing, and I have discovered that it is timing out because I am not receiving any data.
I'm pretty new to Arduinos, so is there something basic I am forgetting? The only modification I made to the sample code was commenting out all of the sections that reference the SD card; I do not have that hooked up yet, I'm trying to get some sort of camera response first. I thought it could be a baud rate problem, but CommTool works perfectly at the default 38400 baud.
Any ideas? Thanks in advance!
