All of a sudden I've been unable to even compile any Arduino code at all. Even the code with an empty setup and loop when opening a new sketch won't compile. Here's the compiler output. The compiler will take much longer than it used to (5+ minutes) to compile even the simple code I mentioned earlier, then say it's done uploading but no sketch will be on my Arduino. I've tried restarting my computer and uninstalling and reinstalling the newest version of Arduino.
Please use the chain links button to make your URLs clickable in the future to make it easier for people to look at the compiler output like this: http://pastebin.com/mkUMM8yG
I think the relevant part of the output is:
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard" "C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino\new.cpp" -o "C:\Users\Drew\AppData\Local\Temp\builda489a3c919fc055ba83a680d57980f4a.tmp\core\new.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Drew\AppData\Local\Temp\builda489a3c919fc055ba83a680d57980f4a.tmp\core\core.a" "C:\Users\Drew\AppData\Local\Temp\builda489a3c919fc055ba83a680d57980f4a.tmp\core\wiring_pulse.S.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Drew\AppData\Local\Temp\builda489a3c919fc055ba83a680d57980f4a.tmp\core\core.a" "C:\Users\Drew\AppData\Local\Temp\builda489a3c919fc055ba83a680d57980f4a.tmp\core\WInterrupts.c.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Drew\AppData\Local\Temp\builda489a3c919fc055ba83a680d57980f4a.tmp\core\core.a" "C:\Users\Drew\AppData\Local\Temp\builda489a3c919fc055ba83a680d57980f4a.tmp\core\hooks.c.o"
C:\Program Files\Arduino\hardware\tools\avr/bin/avr-ar: unable to rename 'C:\Users\Drew\AppData\Local\Temp\builda489a3c919fc055ba83a680d57980f4a.tmp\core\core.a'; reason: File exists
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-ar" rcs "C:\Users\Drew\AppData\Local\Temp\builda489a3c919fc055ba83a680d57980f4a.tmp\core\core.a" "C:\Users\Drew\AppData\Local\Temp\builda489a3c919fc055ba83a680d57980f4a.tmp\core\wiring.c.o"
exit status 1
Error compiling."
metrogdor22:
Try temporarily disabling your antivirus software to see if that's the cause of the slow compile(and maybe the error also).
