So it's been a while since I fired up my Arduino IDE, and when I tried to compile, it shows the error "Error compiling for board Arduino/Genuono" with no other texts. I tried reinstalling the IDE and Java, deleted all temp folders and in the end it's still showing the same error.
I turned on the verbose text and this is what it shows me:
ballscrewbob:
WOW then you really do have an issue.
So we know its win 7 on the latest IDE with a UNO.
Anything connected to the board ?
Does device manager see it ?
Real UNO or a clone ?
Was that just a compile or an upload ?
Any other info you can provide ?
I've tried to do both, same result.
It even shows up in the COM selection in the IDE.
It's real.
It gives the error during compilation, so it doesn't even attempt to even upload.
It does it with any board I selected. At first I thought it's a library issue, then I decided to try it on a blank sketch (the default you get from just opening a new IDE window). Then I tried to make a deliberate syntax error. The error messages given were all identical.
I just realised there was one thing I haven’t tried. I reinstalled the IDE in the D drive and now it works fine.
Still don’t know what was the issue though, cause I’ve deleted the temp folders when I helplessly reinstalled it over and over previously.
