Can't configure S2B modules with x-ctu
I'm trying to configure several modules so I can create a mesh network. But, first of all, I'm only trying with two modules (one coordinator and one router) in API mode (2).
First, with x-ctu, I changed modules function set to coordinator and router API, respectively. It works fine, I can read all default params perfectly.
But, then I want to change some parameters as:
  • Router:
    JV: 0 to 1
    JN: 0 to 1
    NI: ROUTER
    BD: 3 to 6
    AP: 1 to 2
  • Coordinator:
    NI: COORDINATOR
    BD: 3 to 6
    AP: 1 to 2
So, I write this parameters, with ot without, mark 'Always update firmware', it doesn't care, but when I reset the module and read again the parameters, all of them seem erased.
How can I configure these parameters in a right way?? Which is the problem that makes it doesn't write memory correctly?
Because of this, I can't establish communication between modules without doing this first.
Thanks in advance!!
Problem Fixed!!
Problem Fixed!!
This will sure help anyone who has the same issue in the future, and searches the forum for a solution.
