Can't connect Arduino Shield to a fixed IP
I'm trying to connect to a device using an ethernet cable and the device's fixed IP.
When I've tried to connect to another device using DHCP over the server I was able to get a connection but now I am unsuccessful.
This is the sketch I'm using:
#include <SPI.h>
#include <EthernetClient.h>
#include <Ethernet.h>
#define DEBUG
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
IPAddress server(192,168,137,5);  // numeric IP for Google (no DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 137, 5);
IPAddress myDns(192, 168, 137, 1);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
// Variables to measure the speed
unsigned long beginMicros, endMicros;
unsigned long byteCount = 0;
bool printWebData = true;  // set to false for better speed measurement
  pinMode(5, OUTPUT); //set pwm fan
  digitalWrite(5, HIGH);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // start the Ethernet connection:
  #ifdef DEBUG
    Serial.println("Initialize Ethernet with DHCP:");
  #endif
  if (Ethernet.begin(mac, ip, myDns) == 0) {
    #ifdef DEBUG
      Serial.println("Failed to configure Ethernet using DHCP");
    #endif
    // Check for Ethernet hardware present
    if (Ethernet.hardwareStatus() == EthernetNoHardware) {
      #ifdef DEBUG
        Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
      #endif
      while (true) {
        delay(1); // do nothing, no point running without Ethernet hardware
    if (Ethernet.linkStatus() == LinkOFF) {
      #ifdef DEBUG
        Serial.println("Ethernet cable is not connected.");
      #endif
    // try to congifure using IP address instead of DHCP:
    Ethernet.begin(mac, ip, myDns);
    #ifdef DEBUG
      Serial.print("DHCP assigned IP ");
      Serial.println(Ethernet.localIP());
    #endif
  // give the Ethernet shield a second to initialize:
  #ifdef DEBUG
    Serial.print("connecting to ");
    Serial.print(server);
    Serial.println("...");
  #endif
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    #ifdef DEBUG
      Serial.print("connected to ");
      Serial.println(client.remoteIP());
      // Make a HTTP request:
    #endif
    client.println("GET /search?q=arduino HTTP/1.1");
    client.println("Host: www.google.com");
    client.println("Connection: close");
    client.println();
  beginMicros = micros();
  if (client.connected()){
    #ifdef DEBUG
      Serial.println("Decipher is connected");
    #endif
  if (!client.connected()){
    #ifdef DEBUG
      Serial.println("Decipher is not connected");
    #endif
    digitalWrite(5,LOW);
    digitalWrite(5,HIGH);
  delay(7000);
if it's a fixed IP, why use DHCP?
You're connecting to yourself?
Note: 192.168.137.5 is NOT the address of Google.
