# Can't connect PS2 controller with Genuino 101
**URL:** <https://forum.arduino.cc/t/cant-connect-ps2-controller-with-genuino-101/1311709>\
**Category:** Networking, Protocols, and Devices\
**Created:** [October 15, 2024, 11:22pm UTC](https://forum.arduino.cc/t/cant-connect-ps2-controller-with-genuino-101/1311709 "2024-10-15T23:22:03Z")\
**Posts on this page:** 1\
**Showing post:** 5
<div class="post-metadata">
**Author:** ![DerWanderfalke](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/derwanderfalke/32/1098827_2.png) [@DerWanderfalke](https://forum.arduino.cc/u/DerWanderfalke)\
**Post date:** [October 16, 2024, 8:43pm UTC](https://forum.arduino.cc/t/cant-connect-ps2-controller-with-genuino-101/1311709/5 "2024-10-16T20:43:13Z")
</div>
Yup, I can confirm it works from a complile as well as flash perspective. Thanks.
Next, the void setup() didn't return any error inside the serial monitor.
The workaround was to add
```arduino
while (!Serial) {}
after opening the serial monitor, as described here:
[Serial.print in void setup - Using Arduino / IDE 1.x - Arduino Forum](https://forum.arduino.cc/t/serial-print-in-void-setup/668654)
So it seems the Arduino101 does not have that "special reset circuit" contrary to the typical Arduinos.
Anyway, now the error is:
> No controller found, check wiring, see readme.txt to enable debug.
I think the wiring is correct. So it is either the PS2 controller damaged, or some other topic related to the Arduino/Genuino 101 platform, be it compatiblity from a SW perspective, or HW perspective (it seems the 101 supports 3.3 V)...
_[View the full topic](https://forum.arduino.cc/t/cant-connect-ps2-controller-with-genuino-101/1311709)._
