I keep trying to connect to my FTP server using the Wifi shield. I input the correct username and password but it keeps failing.
Here's the code i'm using
This sketch connects to a Wifi network.
Then it prints the MAC address of the Wifi shield,
the IP address obtained, and other network details.
Then transfer file from SD card on ftp server (if press f)
Circuit:
* WiFi shield attached
created 13 July 2010
by dlf (Metodo2 srl)
modified 31 May 2012
by Tom Igoe -- WiFi part
October 2012 by SurferTim -- ftp part
October 2013 by Pashkot -- put the parts together (Arduino IDE 1.0.5, Arduino UNO R3)
#include <WiFi.h>
#include <SD.h>
#include <SPI.h>
// comment out next line to write to SD from FTP server
//#define FTPWRITE
char ssid[] = "FIU_WiFi"; // your network SSID (name)
//char pass[] = "mypassowrd"; // your network password
int status = WL_IDLE_STATUS; // the Wifi radio's status
// change to your server
IPAddress server( xx, xx, xxx, xxx );
WiFiClient client;
WiFiClient dclient;
char outBuf[128];
char outCount;
// change fileName to your file (8.3 format!)
//char fileName[13] = "PIC_1204.JPG";
char fileName[13] = "test.txt";
//Initialize serial and wait for port to open:
//while (!Serial) {
//; // wait for serial port to connect. Needed for Leonardo only
pinMode(10,OUTPUT);
digitalWrite(10,HIGH);
if(SD.begin(4) == 0)
Serial.println(F("SD init fail"));
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while(true);
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the data:
Serial.print("You're connected to the network ");
printCurrentNet();
printWifiData();
Serial.print("FTP server:");
Serial.println(server);
Serial.println(F("Ready. Press f or r"));
// check the network connection once every 10 seconds:
//delay(10000);
//printCurrentNet();
byte inChar;
inChar = Serial.read();
if(inChar == 'f')
if(doFTP()) Serial.println(F("FTP OK"));
else Serial.println(F("FTP FAIL"));
if(inChar == 'r')
readSD();
File fh;
byte doFTP()
#ifdef FTPWRITE
fh = SD.open(fileName,FILE_READ);
#else
SD.remove(fileName);
fh = SD.open(fileName,FILE_WRITE);
#endif
if(!fh)
Serial.println(F("SD open fail"));
return 0;
#ifndef FTPWRITE
if(!fh.seek(0))
Serial.println(F("Rewind fail"));
fh.close();
return 0;
#endif
Serial.println(F("SD opened"));
if (client.connect(server,21)) {
Serial.println(F("Command connected"));
else {
fh.close();
Serial.println(F("Command connection failed"));
return 0;
if(!eRcv()) return 0;
client.println(F("USER xxxxx"));
client.println(F("PASS xxxxxxxx"));
client.println(F("SYST\r\n"));
client.println(F("PASV\r\n"));
char *tStr = strtok(outBuf,"(,");
int array_pasv[6];
for ( int i = 0; i < 6; i++) {
tStr = strtok(NULL,"(,");
array_pasv[i] = atoi(tStr);
if(tStr == NULL)
Serial.println(F("Bad PASV Answer"));
unsigned int hiPort,loPort;
hiPort = array_pasv[4] << 8;
loPort = array_pasv[5] & 255;
Serial.print(F("Data port: "));
hiPort = hiPort | loPort;
Serial.println(hiPort);
if (dclient.connect(server,hiPort)) {
Serial.println(F("Data connected"));
else {
Serial.println(F("Data connection failed"));
client.stop();
fh.close();
return 0;
#ifdef FTPWRITE
client.print(F("STOR "));
client.println(fileName);
#else
client.print(F("RETR "));
#endif
if(!eRcv())
dclient.stop();
return 0;
#ifdef FTPWRITE
Serial.println(F("Writing"));
byte clientBuf[64];
int clientCount = 0;
while(fh.available())
clientBuf[clientCount] = fh.read();
clientCount++;
if(clientCount > 63)
dclient.write(clientBuf,64);
clientCount = 0;
if(clientCount > 0) dclient.write(clientBuf,clientCount);
#else
while(dclient.connected())
while(dclient.available())
char c = dclient.read();
fh.write(c);
Serial.write(c);
#endif
dclient.stop();
Serial.println(F("Data disconnected"));
client.println(F("QUIT"));
client.stop();
Serial.println(F("Command disconnected"));
fh.close();
Serial.println(F("SD closed"));
return 1;
byte eRcv()
byte respCode;
byte thisByte;
while(!client.available()) delay(1);
respCode = client.peek();
outCount = 0;
while(client.available())
thisByte = client.read();
Serial.write(thisByte);
if(outCount < 127)
outBuf[outCount] = thisByte;
outCount++;
outBuf[outCount] = 0;
if(respCode >= '4')
efail();
return 0;
return 1;
void efail()
byte thisByte = 0;
client.stop();
fh.close();
void readSD()
if(!fh)
return;
Serial.write(fh.read());
fh.close();
void printWifiData() {
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC address: ");
Serial.print(mac[5],HEX);
Serial.print(":");
Serial.print(mac[4],HEX);
Serial.print(":");
Serial.print(mac[3],HEX);
Serial.print(":");
Serial.print(mac[2],HEX);
Serial.print(":");
Serial.print(mac[1],HEX);
Serial.print(":");
Serial.println(mac[0],HEX);
void printCurrentNet() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print the MAC address of the router you're attached to:
byte bssid[6];
WiFi.BSSID(bssid);
Serial.print("BSSID: ");
Serial.print(bssid[5],HEX);
Serial.print(":");
Serial.print(bssid[4],HEX);
Serial.print(":");
Serial.print(bssid[3],HEX);
Serial.print(":");
Serial.print(bssid[2],HEX);
Serial.print(":");
Serial.print(bssid[1],HEX);
Serial.print(":");
Serial.println(bssid[0],HEX);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.println(rssi);
// print the encryption type:
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type:");
Serial.println(encryption,HEX);
