Can't connect to port 8883 with 5100 Shield
I'm new to using the ethernet shield.
I'm able to connect to my mqtt server using the arduino insecurely (over port 1883).
I'm able to connect to my mqtt server using a raspberry pi securely (over port 8883).
However, I cannot connect to port 8883 with the arduino.
I've read every post out there and I can't tell if it's my sketch or it's just impossible. Can someone tell me definitively if it won't work or what the problem is with my code?
#include <SPI.h>
#include <Ethernet.h>
#include "PubSubClient.h"
//#define CLIENT_ID         "BoilerRoom"
//#define USERNAME        ""
//#define PASSWORD        ""
//#define SERVER             "192.168.0.222"
//#define PORT                 1883
#define USERNAME      "mudmin"
#define PASSWORD     "password"
#define SERVER          "mqttserver.domain.com"
#define PORT              8883
#define INTERVAL        3000 // 3 sec delay between publishing
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,0,223);
EthernetClient ethClient;
PubSubClient mqttClient;
long previousMillis;
    // disable SD card if one in the slot
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  // setup serial communication
  // setup ethernet communication using DHCP
  if(Ethernet.begin(mac) == 0) {
    Serial.println(F("Ethernet configuration using DHCP failed"));
    for(;;);
  // setup mqtt client
  mqttClient.setClient(ethClient);
  mqttClient.setServer(SERVER,PORT);
  Serial.println(F("MQTT client configured"));
  previousMillis = millis();
  // check interval
  if(millis() - previousMillis > INTERVAL) {
    sendData();
  mqttClient.loop();
void sendData() {
  char msgBuffer[20];
  if(mqttClient.connect(CLIENT_ID, USERNAME, PASSWORD)) {
   mqttClient.publish("hello", "world");
Does the Arduino support HTTPS?
Last time I checked it didn't because of memory and processing constraints.
One hack is to use point to point WiFi with WPA encryption instead of a wired connection. You'll still be using HTTP but it'll be secure.
I was originally trying on a nano and someone said it didn't have enough memory, so I moved to a mega hoping that would work.
I do have the option of going to another device...but I would really like https if at all possible.
