Can't connect with USB modem Device on Nano V. 3 Help
I am using Processing 2.0.3 and the Arduino boards as discussed below.
When I use my Uno board and print out the Arduino.list(), I get these devices:
[0] "/dev/tty.Bluetooth-Serial-1"
[1] "/dev/cu.Bluetooth-Serial-1"
[2] "/dev/tty.Bluetooth-Serial-2"
[3] "/dev/cu.Bluetooth-Serial-2"
[4] "/dev/tty.Bluetooth-Modem"
[5] "/dev/cu.Bluetooth-Modem"
[6] "/dev/tty.Bluetooth-PDA-Sync"
[7] "/dev/cu.Bluetooth-PDA-Sync"
[8] "/dev/tty.usbmodem14221"
[9] "/dev/cu.usbmodem14221"
I can set my Arduino object to list item [8] and my program works fine.
However, when I switch to the Nano v. 3 board and list my devices, I get this:
Experimental: JNI_OnLoad called.
There is no "dev/tty.usbmodem14221" listed and so my sketch does not work.
Can anyone shed light on why I'm not showing the device I need?
MacMini, OS X 10.8.5.
Missing FTDI drivers ?
// Per.
