can't conpare two strings
Hi, i wrote this code
String act;
void setup(){
Serial.println("conected");
void loop(){
if (Serial.available()>0)
act = Serial.readString();
if (act == "on")
Serial.println("==, on");
if (act.equals("on"))
 Serial.println("equal, on");
the problem is, that even if i send in the monitor on it's not recognize it.
Is someone know what the problem?
i use pro mini, if it's importent.
Your code is incomplete.
if (act == "on"") Oops
TheMemberFormerlyKnownAsAWOL:
you are right, but the mistake is in what i type here, in the sorce it’s ok and the code compile.
Ok, when you’ve got a relevant question, and the code to go with it (not pictures), get back to us.
Ok, when you've got a relevant question, and the code to go with it (not pictures), get back to us.
All the code write in my first mesage, i atached picture to show that the mistake is was here, and not in my orginal code, and i have problem, . i wrote it in my first massege, mabey it's not cleraly, its because my english not very well.
The code in the first post doesn’t compile for a number of reasons, the most obvious of which is that it is incomplete.
Change the "Line Ending Feed" of the Serial Monitor to "None"
you right, because the tiredness (the time in my city is 1:19 at night…) i forgot two ‘}’.
arduino_new:
it's working :slight_smile: thank to both of you.
now i need to see why it's not work with the max485... but i think this will be only tomrrow...
