how to provide delay on debouncing programs?
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
IPAddress ip(10, 14, 206, 116);
EthernetClient client;
IPAddress server(10, 14, 206, 64); //computer
unsigned long lastConnectionTime = 0; // last time you connected to the server, in milliseconds
unsigned long debounceDelay = 50; // last time you connected to the server, in milliseconds
const unsigned long postingInterval = 10 * 1000; // delay between updates, in milliseconds
int temp1[2];
int temp2[2];
int temp3[2];
int temp4[2];
int temp5[2];
int temp6[2];
int stat1;
int stat2;
int stat3;
int stat4;
int stat5;
int stat6;
int bt1 = A14;
int bt2 = A13;
int bt3 = A12;
int bt4 = A11;
int bt5 = A10;
int bt6 = A8;
bool lock1 = true;
bool lock2 = true;
bool lock3 = true;
bool lock4 = true;
bool lock5 = true;
bool lock6 = true;
pinMode(bt1, INPUT);
pinMode(bt2, INPUT);
pinMode(bt3, INPUT);
pinMode(bt4, INPUT);
pinMode(bt5, INPUT);
pinMode(bt6, INPUT);
while (!Serial) { ;}
Serial.println("Initialize Ethernet with DHCP:");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1);
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
Ethernet.begin(mac, ip);
Serial.print("My IP address: ");
Serial.println(Ethernet.localIP());
Serial.print(" DHCP assigned IP ");
delay(2000);
temp1[0] = digitalRead(bt1);
temp1[1] = digitalRead(bt1);
temp2[0] = digitalRead(bt2);
temp2[1] = digitalRead(bt2);
temp3[0] = digitalRead(bt3);
temp3[1] = digitalRead(bt3);
temp4[0] = digitalRead(bt4);
temp4[1] = digitalRead(bt4);
temp5[0] = digitalRead(bt5);
temp5[1] = digitalRead(bt5);
temp6[0] = digitalRead(bt6);
temp6[1] = digitalRead(bt6);
if (client.available()) {
char c = client.read();
Serial.write(c);
if (temp1[0] != temp1[1] && lock1==true) {
stat1 = temp1[0];
temp1[1] = temp1[0];
httpRequest();
else if (temp1[0] = temp1[1])
{lock1=true;}
if (temp2[0] !=temp2[1] && lock2==true) {
stat2 = temp2[0];
temp2[1] = temp2[0];
httpRequest();
else if (temp2[0] = temp2[1])
{lock2=true;}
if (temp3[0] !=temp3[1] && lock3==true) {
stat3 = temp3[0];
temp3[1] = temp3[0];
httpRequest();
else if (temp3[0] = temp3[1])
{lock3=true;}
if (temp4[0] != temp4[1] && lock4==true) {
stat4 = temp4[0];
temp4[1] = temp4[0];
httpRequest();
else if (temp4[0] = temp4[1])
{lock4=true;}
if (temp5[0] != temp5[1] && lock5==true) {
stat5 = temp5[0];
temp5[1] = temp5[0];
httpRequest();
else if (temp5[0] = temp5[1])
{lock5=true;}
if (temp6[0] != temp6[1] && lock6==true) {
stat6 = temp6[0];
temp6[1] = temp6[0];
httpRequest();
else if (temp6[0] = temp6[1])
{lock6=true;}
void httpRequest() {
client.stop();
if (client.connect(server, 80)) {
Serial.println("connecting...");
if (stat6==1) client.println("GET /line_stop/ethernet0.php?a=1 HTTP/1.1");
if (stat6==0) client.println("GET /line_stop/ethernet0.php?b=0 HTTP/1.1");
client.println("Host: 10.14.206.64");
client.println("User-Agent: arduino-ethernet");
client.println("Connection: close");
client.println();
lastConnectionTime = millis();
Serial.println("connection failed");
if (stat1==1) client.println("GET /line_stop/ethernet1.php?c=1 HTTP/1.1");
if (stat1==0) client.println("GET /line_stop/ethernet1.php?d=0 HTTP/1.1");
client.println();
if (stat2==1) client.println("GET /line_stop/ethernet2.php?e=1 HTTP/1.1");
if (stat2==0) client.println("GET /line_stop/ethernet2.php?f=0 HTTP/1.1");
client.println();
if (stat3==1) client.println("GET /line_stop/ethernet3.php?g=1 HTTP/1.1");
if (stat3==0) client.println("GET /line_stop/ethernet3.php?h=0 HTTP/1.1");
client.println();
if (stat4==1) client.println("GET /line_stop/ethernet4.php?i=1 HTTP/1.1");
if (stat4==0) client.println("GET /line_stop/ethernet4.php?j=0 HTTP/1.1");
client.println();
if (stat5==1) client.println("GET /line_stop/ethernet5.php?k=1 HTTP/1.1");
if (stat5==0) client.println("GET /line_stop/ethernet5.php?l=0 HTTP/1.1");
client.println();
