Can't debug Code, to show change in temperature as colour with a RGB
This should help some.
int temperaturePin = 0;
int LED[] = {
  9, 10, 11}; //sets the pins
//9 = RED, 10=GREEN, 11= BLUE
const boolean ON = LOW;  //defines ON as LOW
const boolean OFF = HIGH;  //defines OFF as HIGH
//Predefined Colors
const boolean RED[] = {
  ON, OFF, OFF};
const boolean GREEN[] = {
  OFF, ON, OFF};
const boolean BLUE[] = {
  OFF, OFF, ON};
const boolean YELLOW[] = {
  ON, ON, OFF};
const boolean CYAN[] = {
  OFF, ON, ON};
const boolean MAGENTA[] = {
  ON, OFF, ON};
const boolean WHITE[] = {
  ON, ON, ON};
const boolean BLACK[] = {
  OFF, OFF, OFF};
  for(int i = 0; i < 3; i++){
    pinMode(LED[i], OUTPUT);   //Set the three LED pins as outputs
  Serial.begin(115200);  //Start the serial connection with the copmuter
  //to view the result open the serial monitor
  //last button beneath the file bar (looks like a box with an antenae)
 * getVoltage() - returns the voltage on the analog input defined by
   * pin
float getVoltage(int pin)
  return (analogRead(pin) * .004882814); //converting from a 0 to 1023 digital range
  // to 0 to 5 volts (each 1 reading equals ~ 5 millivolts
} //converting from a 0 to 1023 digital range
  float temperature = getVoltage(temperaturePin);  //getting the voltage reading from the temperature sensor
  temperature = (temperature - .5) * 100;          //converting from 10 mv per degree wit 500 mV offset
  Serial.print(temperature);
  Serial.println(" degrees centigrade");
  if(temperature < 430){
    setColor(LED, BLUE);
  else{
    if(temperature >430 && temperature <440){
      setColor(LED, GREEN);
    else {
      if(temperature >440 && temperature <450)
      else{
        setColor(LED, BLACK);
void setColor(int* led, boolean* color){
  for (int i = 0; i < 3; i++) {
    digitalWrite(led[i], color[i]);
void setColor(int* led, const boolean* color){
  boolean tempColor[] = { color[0], color[1], color[2]  };
  setColor(led, tempColor);
