Can't declare a variable.
I wrote this code to test random numbers and don't understand what's wrong with it. I keep getting this error:
"exit status 1
'ran' was not declared in this scope"
Here is my entire code:
"void setup() {
digitalWrite(LED_BUILTIN, LOW);
randomSeed(analogRead(0));
int randomNumber;
randomNumber = random(1,4);
if (randomNumber = 1)
{ digitalWrite(LED_BUILTIN, HIGH);
if (randomNumber = 2)
{ digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(500); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
delay(500);// wait for a second
if (randomNumber = 3)
if (randomNumber = 4)
delay(6000)
}" Thanks if you have any idea what's wrong. I don't know much about this but from what I googled this should work.
Firstly, you don't put ; after } as you do in a number of places...
And you have declared randomNumber (not "ran" though?) inside setup() which means it can't be seen inside loop(). Declare it as a so-called global variable above setup().
And once you lose all those spurious ; after the }, you have an extra } at the end, and a missing ; after that last delay().
Then once it compiles you need to read up on how not to use = in an if:
I think your Google is broken.
