Can't delete IDE 2 preferences on macOS
I'm trying to reinstall the Arduino IDE 2.0 from a 100% clean state on macOS, but despite deleting ~/Arduino15 and my best efforts to find and delete all Arduino files in ~/Library, when I reinstall the IDE, it still remembers preferences such as the IDE theme and board manager URLs.
Can somebody tell me where these preferences are saved?
(It's not ~/Library/Preferences/cc.arduino.IDE2.plist, because I deleted that one too.)
This is actually blocking my work because I've somehow arrived in a state that produces a bug that seemingly can't be reproduced on other computers, so it's important that I remove all traces of Arduino.
Thank you for any suggestions!
Did you reboot or logout after deleting the files?
Hi @scottamain. Unlike Arduino IDE 1.x, 2.x does not store preferences in that Arduino15 folder.
There are two other folders it uses to store information:
~/.arduinoIDE/
~/Library/Application Support/arduino-ide/
Clearing those should be adequate to put your system back into the pre-install state.
Thank you for the quick response, @ptillisch! Indeed the .arduinoIDE path had evaded me and that's where these preferences were held.
Bitter-sweet result, though, because although that did not solve the issue I was trying to smoke-out, eliminating that theory did refocus my efforts and I discovered the root cause somewhere else completely (not in the IDE). Whew!
You are welcome. I'm glad you were able to solve the problem after all.
Regards,
Per
Just being curious here - That’s not a good practice on macOS… why was this choice made when there is a full preference API available and documented?
