Cant Display Cryptocurrency price from Coingecko on a Nodemcu (seems related to https url)
I am using a Nodemcu to try to read a cryptocurrency API from coingecko and display on serial monitor, code is below. I get a HttpCode of -1 but not sure why?
The target url below works in a browser.
If I substitute this url for a http based address it works but dropping the s from the coingecko url still does not work.
Any suggestions?
https://api.coingecko.com/api/v3/simple/price?ids=star-atlas&vs_currencies=usd
void display_prices(void) {
  if (WiFi.status() == WL_CONNECTED) { //Check WiFi connection status
    Serial.println("");
    Serial.println("connection check = OK");
    HTTPClient http;  //Declare an object of class HTTPClient
    http.begin("https://api.coingecko.com/api/v3/simple/price?ids=star-atlas&vs_currencies=usd");  //Specify request destination
    int httpCode = http.GET();     //Send the request
      Serial.print("HttpCode = ");
      Serial.println(httpCode);
    if (httpCode > 0) { //Check the returning code
      String payload = http.getString();   //Get the request response payload
      Serial.print("payload = ");
      Serial.println(payload);                     //Print the response payload
    http.end();   //Close connection
    Serial.println("connection closed");
Did you get this message?
/Users/john/Documents/Arduino/sketch_feb22a/sketch_feb22a.ino: In function 'void display_prices()':
sketch_feb22a:14:15: error: call to 'HTTPClient::begin' declared with attribute error: obsolete API, use ::begin(WiFiClient, url)
   14 |     http.begin("https://api.coingecko.com/api/v3/simple/price?ids=star-atlas&vs_currencies=usd");  //Specify request destination
exit status 1
You should try it this way:
    WiFiClient wifiClient;
    http.begin(wifiClient, "https://api.coingecko.com/api/v3/simple/price?ids=star-atlas&vs_currencies=usd");  //Specify request destination
Thanks,
No didnt get that error...
When I try your code the result on the serial window is below
HttpCode = 400
payload = <html>
<head><title>400 The plain HTTP request was sent to HTTPS port</title></head>
<body>
<center><h1>400 Bad Request</h1></center>
<center>The plain HTTP request was sent to HTTPS port</center>
<hr><center>cloudflare</center>
</body>
</html>
connection closed
Looks like you have to add more code to establish a secure connection. Try starting with the "BasicHttpsClient" example.
OK, I tried the Basic Https Client example but that doesnt work at all, do you or anyone have working code for Https, why is this so complex?
Serial Monitor Shows
[HTTPS] begin...
[HTTPS] GET...
[HTTPS] GET... failed, error: connection failed
Wait 10s before next round...
I am using
   BasicHTTPSClient.ino
    Created on: 20.08.2018
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClientSecureBearSSL.h>
// Fingerprint for demo URL, expires on June 2, 2021, needs to be updated well before this date
const uint8_t fingerprint[20] = {0x40, 0xaf, 0x00, 0x6b, 0xec, 0x90, 0x22, 0x41, 0x8e, 0xa3, 0xad, 0xfa, 0x1a, 0xe8, 0x25, 0x41, 0x1d, 0x1a, 0x54, 0xb3};
ESP8266WiFiMulti WiFiMulti;
  // Serial.setDebugOutput(true);
  for (uint8_t t = 4; t > 0; t--) {
    Serial.printf("[SETUP] WAIT %d...\n", t);
    Serial.flush();
  WiFi.mode(WIFI_STA);
  WiFiMulti.addAP("ssid", "password");
  // wait for WiFi connection
  if ((WiFiMulti.run() == WL_CONNECTED)) {
    std::unique_ptr<BearSSL::WiFiClientSecure>client(new BearSSL::WiFiClientSecure);
    client->setFingerprint(fingerprint);
    HTTPClient https;
    Serial.print("[HTTPS] begin...\n");
    if (https.begin(*client, "https://jigsaw.w3.org/HTTP/connection.html")) {  // HTTPS
      Serial.print("[HTTPS] GET...\n");
      // start connection and send HTTP header
      int httpCode = https.GET();
      // httpCode will be negative on error
      if (httpCode > 0) {
        // HTTP header has been send and Server response header has been handled
        Serial.printf("[HTTPS] GET... code: %d\n", httpCode);
        // file found at server
        if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_MOVED_PERMANENTLY) {
          String payload = https.getString();
        Serial.printf("[HTTPS] GET... failed, error: %s\n", https.errorToString(httpCode).c_str());
      https.end();
      Serial.printf("[HTTPS] Unable to connect\n");
  Serial.println("Wait 10s before next round...");
  delay(10000);
I think you need a new "fingerprint" to get the example to work. I just checked the source and they have not updated it.
This seems to be the documentation for the ESP8266WiFi BearSSL library:
https://arduino-esp8266.readthedocs.io/en/latest/esp8266wifi/bearssl-client-secure-class.html
If you don't care to protect yourself against a server impersonating your target server, you can call:
client->setInsecure();
instead of:
If you can get the server's Public Key you can use that instead of a fingerprint:
client->setKnownKey(const BearSSL::PublicKey *pk);
Thank you.
I tried it as insecure and it works!
Now the next step is merging this code with WiFi Manager which have working by itself.
I have merged the code below but now will not connect, could I pick your brain again...?
Thanks again.
//#include <ESP8266HTTPClient.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>         // https://github.com/tzapu/WiFiManager
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET     -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C
///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
// Auxiliar variables to store the current output state
String output5State = "off";
String output4State = "off";
// Assign output variables to GPIO pins
const int output5 = 5;
const int output4 = 4;
  // Initialize the output variables as outputs
  pinMode(output5, OUTPUT);
  pinMode(output4, OUTPUT);
  // Set outputs to LOW
  digitalWrite(output5, LOW);
  digitalWrite(output4, LOW);
  // WiFiManager
  // Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  // Uncomment and run it once, if you want to erase all the stored information
  //wifiManager.resetSettings();
  // set custom ip for portal
  //wifiManager.setAPConfig(IPAddress(10,0,1,1), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
  // fetches ssid and pass from eeprom and tries to connect
  // if it does not connect it starts an access point with the specified name
  // here  "AutoConnectAP"
  // and goes into a blocking loop awaiting configuration
  wifiManager.autoConnect("Bazooka");
  // wifiManager.autoConnect("AutoConnectAP");
  // or use this for auto generated name ESP + ChipID
  //wifiManager.autoConnect();
  // if you get here you have connected to the WiFi
  Serial.println("Connected.");
  server.begin();
void loop(){
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
  // Show initial display buffer contents on the screen --
  // the library initializes this with an Adafruit splash screen.
  //display.display();
  //delay(2000); // Pause for 2 seconds
  // Clear the buffer
  display.clearDisplay();
  display.drawPixel(10, 10, SSD1306_WHITE);
  display.display();
  //delay(2000);
  Lookup_Price_by_https();
  //display_prices();
  //display_test();
  WiFiClient client = server.available();   // Listen for incoming clients
  if (client) {                             // If a new client connects,
    Serial.println("New Client.");          // print a message out in the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected()) {            // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        header += c;
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println("Connection: close");
            client.println();
            // turns the GPIOs on and off
            if (header.indexOf("GET /5/on") >= 0) {
              Serial.println("GPIO 5 on");
              output5State = "on";
              digitalWrite(output5, HIGH);
            } else if (header.indexOf("GET /5/off") >= 0) {
              Serial.println("GPIO 5 off");
            } else if (header.indexOf("GET /4/on") >= 0) {
              Serial.println("GPIO 4 on");
              output4State = "on";
              digitalWrite(output4, HIGH);
            } else if (header.indexOf("GET /4/off") >= 0) {
              Serial.println("GPIO 4 off");
            // Display the HTML web page
            client.println("<!DOCTYPE html><html>");
            client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
            client.println("<link rel=\"icon\" href=\"data:,\">");
            // CSS to style the on/off buttons
            // Feel free to change the background-color and font-size attributes to fit your preferences
            client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
            client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
            client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
            client.println(".button2 {background-color: #77878A;}</style></head>");
            // Web Page Heading
            client.println("<body><h1>ESP8266 Web Server</h1>");
            // Display current state, and ON/OFF buttons for GPIO 5
            client.println("<p>GPIO 5 - State " + output5State + "</p>");
            // If the output5State is off, it displays the ON button
            if (output5State=="off") {
              client.println("<p><a href=\"/5/on\"><button class=\"button\">ON</button></a></p>");
              client.println("<p><a href=\"/5/off\"><button class=\"button button2\">OFF</button></a></p>");
            // Display current state, and ON/OFF buttons for GPIO 4
            client.println("<p>GPIO 4 - State " + output4State + "</p>");
            // If the output4State is off, it displays the ON button
            if (output4State=="off") {
              client.println("<p><a href=\"/4/on\"><button class=\"button\">ON</button></a></p>");
              client.println("<p><a href=\"/4/off\"><button class=\"button button2\">OFF</button></a></p>");
            client.println("</body></html>");
            // The HTTP response ends with another blank line
            client.println();
            // Break out of the while loop
          } else { // if you got a newline, then clear currentLine
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("Client disconnected.");
    Serial.println("");
  display.setTextSize(1);             // Normal 1:1 pixel scale
  display.setTextColor(SSD1306_WHITE);        // Draw white text
  display.setCursor(30,10);             // Start at top-left corner
  display.println(F("STAR LAUNCH"));
  display.setTextSize(2);             // Normal 1:1 pixel scale
  display.setCursor(20,30);             // Start at top-left corner
  display.println(("$xxxxxx"));
  display.display();
  delay(2000);
void display_test(void) {
  display.setCursor(30,2);             // Start at top-left corner
  display.println(F("TEST"));
  display.display();
  delay(2000);
void Lookup_Price_by_https() {
    HTTPClient https;
    if (https.begin(*client, "https://api.coingecko.com/api/v3/simple/price?ids=star-atlas&vs_currencies=usd")) {  // HTTPS
      if (httpCode > 0) {
      https.end();
  delay(10000);
I don't see anything obviously wrong. Show me the contents of Serial Monitor.
Just doesnt connect to previously configured
Sorry, have been in a flood effected area here in Australia, had no internet or mobile phone coverage for 2 weeks! On testing again it IS working, thanks for your help with this.
