Can't display images on Arduino 4 wifi module simple wifi server
I am trying to set up a simple wifi server using the supplied example, and to be fair, it all works fine, the text and formatting is rendered fine. That is, until I try to display images.
client.println("<img src='http://www.fountainpen.atwebpages.com/images/mont_blanc_pen.jpg' />");
client.println("<img src='www.fountainpen.atwebpages.com/images/mont_blanc_pen.jpg' />");
client.println("<img src='fountainpen.atwebpages.com/images/mont_blanc_pen.jpg' />");
These are the three ways I've tried, but I always end up with a broken link icon appearing on the browser. When I type the third of those directly into the browsers address line, the image does appear. What is stopping the images from being displayed?
Here is the entire sketch:
  WiFi Web Server
 A simple web server that shows the value of the analog input pins.
 This example is written for a network using WPA encryption. For
 WEP or WPA, change the WiFi.begin() call accordingly.
 Circuit:
 * Analog inputs attached to pins A0 through A5 (optional)
 created 13 July 2010
 by dlf (Metodo2 srl)
 modified 31 May 2012
 by Tom Igoe
#include "WiFiS3.h"
#include "arduino_secrets.h" #include <Wire.h>
#include "DHT.h"
#define DHTTYPE DHT22
uint8_t DHTPin = 6;
DHT dht(DHTPin, DHTTYPE);
float Temperature;
float Humidity;
float Temp_Centigrade;
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = "*********";        // your network SSID (name)
char pass[] = "******";    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;                 // your network key index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
  pinMode(DHTPin, INPUT);
  dht.begin();
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to WiFi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  server.begin();
  // you're connected now, so print out the status:
  printWifiStatus();
 Humidity = dht.readHumidity();
  // Read temperature as Celsius (the default)
  Temperature = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  Temp_Centigrade = dht.readTemperature(false);
  // Check if any reads failed and exit early (to try again).
  if (isnan(Humidity) || isnan(Temperature) || isnan(Temp_Centigrade)) {
    Serial.println(F("Failed to read from DHT sensor!"));
    return;
  Serial.print("Current temp in degrees C is:");
  Serial.println(Temp_Centigrade);
  // listen for incoming clients
  WiFiClient client = server.available();
  if (client) {
    Serial.println("new client");
    // an HTTP request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the HTTP request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard HTTP response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // output the value of each analog input pin
          client.println("<body>");
          client.println("<h1 style='color:red';>Message for Clare </h1><br /><br />");
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("<br />");
          client.println("<hr />");
          client.println("Current temperature in Celsius is:");
          client.println("<span style='color:green;font-size:20px;'>");
          client.println(Temp_Centigrade);
          client.println("</span><br /><br />");
          client.println("</body");
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        } else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(5000);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
regards,
Kevin
Please post a complete sketch that illustrates the problem
