Can't exit While loop
I'm having trouble getting my code to exit the while loop for an inflation/vacuum cycling setup on a pneumatic system. I'm trying to inflate to 1.00PSI and then vacuum to 0.2 PSI and then repeat.
The arduino input is connected to a pressure transducer as input to A0 with the output being a solenoid to D4.
I'm getting the correct PSI reading using the serial monitor within the loop but it doesn't exit the while loop when the level is reached.
I've tried a few different ways and if loops but can't seem to get it. Not sure what I'm doing wrong.
int solenoidPin = 4;    //This is the output pin on the Arduino
int cycles;
const int analogPin = A0;
float PSI;
bool inflatestatus = false;
  pinMode(solenoidPin, OUTPUT);           //Sets the pin as an output
      while (! Serial); // Wait untilSerial is ready - Leonardo
      Serial.println("Inflation/Deflation Cycling Jig");
   float PSI = ( analogRead(A0) - 204.80 ) * 15.00 /  ( 1024 - 204.80 );
      if(!inflatestatus)
                    while (PSI < 1.00)
                              digitalWrite(solenoidPin, HIGH);     //Switch Solenoid OFF
                              delay(250);
                              Serial.print(PSI);
                              Serial.print("PSI ");
      inflatestatus = true;
      if(inflatestatus)
                   while (PSI > 0.2)
                              digitalWrite(solenoidPin, LOW);    //Switch Solenoid ON
                              delay(250);
                              Serial.print(PSI);
                cycles ++;
                Serial.print(cycles);
                Serial.println('\n');
Because inside the loop, you are using another variable PSI.
Awesome, thank you
