I feel like I did this way back a long time ago but now I can't get it to work.
I have a Digispark ATTiny85 and I want to enable Timer1 in fast PWM mode and pick up the square wave off 1 of the pins. I tried to figure it out from both the datasheet and from other people's examples but I could not pick up the wave on any pin. The only thing I succeeded in doing is manually forcing a square wave using interrupts but I believe that's creating glitches in the wave and is too slow. Really I just want to set the timer and have the wave come out on one of the pins. What am I doing wrong?
boolean flag = false; //need something quick to flip in the ISR
boolean state = false; //a means of toggling the output pin state
int pot;
int interval = 255; //a variable used to change the OCR number
int count = 0;
pinMode(4, OUTPUT); //Set the output pin
TCCR1 = 0; // Clearing registers
TCNT1 = 0;
GTCCR = _BV(PSR1);
TCCR1 = 0b10001111; // CTC mode and prescaler to max
GTCCR = 0b00110000; // Enable channels A and B
OCR1A = 0; // Counter start value
OCR1C = 255; // Compare match value (slowest RPM)
TIMSK = _BV(OCIE1A); // Enable interrupt vector
sei(); // Enable global interrupts
pot = analogRead(A0); // Read the pot as 10 bit number
// INSERT ACCEL, BRAKE AND PERIOD CODE HERE
// OCR1C = interval;
// SIMULATION CODE
if(count == 1000) { // To see what happens with a simple RPM ramp
OCR1C -= 1;
if(OCR1C == 0)
OCR1C = 255;
count = 0;
count++;
// END SIMULATION CODE
if(flag == true) {
flag = false;
state = !state;
digitalWrite(4, state);
ISR(TIMER1_COMPA_vect)
flag = true;
Gahhhrrrlic:
I'm not the author of that thread but interesting nonetheless.
I'm well aware that you are not the author of that article, who, incidentally, is a prolific poster in the Display forum here. I mentioned it because it appears to describe your problem and am pleased to hear that you find it interesting.
You are trying to write to digital pin 4 (PB4 / OC1B ) on the ATtiny85 directly from timer 1. That is exactly the problem described in the quoted article. Is digital pin 1 (PB1 / OC1A) free. You could try using that instead.
In general it's the COM (Compare Output Mode) bits in that determine if an output pin is controlled by a timer or not. The bits for OCR1A are in TCCR1 (Timer/Counter Control Register 1). The bits for OCR1B are in GTCCR (General Timer Counter Control Register). THE ATtiny85 HAS NO 'COM' BITS FOR OCR1C.
In my code above I tried to enable the COM bits in GTCCR but it didn't appear to have any effect on any of the pins. They were all dead except PB5 which was at 5V steady the whole time for some reason. Soon as I moved to an interrupt based system, I started seeing a wave but not before.
6v6gt my mistake. The way you spoke, I read it in a way that I thought you were saying that article was "mine".
After reading the discussion in post 2, it looks like there was no resolution to the problem. Enabling all the appropriate registers did not put the wave on the corresponding output pin, as expected. Does this mean it's not possible or merely that at the time of that discussion it had not been discovered yet?
