I tried using GPIO 4/5 Data/Clock for wire on my ESP8266 12E and a wire scanner on an Uno can't find it. It only finds my LCD display. Is there anything else I need to do to get Wire working on the ESP8266?
13:02:01.578 -> Scanning...
13:02:01.578 -> No I2C devices found
13:02:01.578 ->
Code on ESP8266
// Wire Master Reader
// by devyte
// based on the example of the same name by Nicholas Zambetti <http://www.zambetti.com>
// Demonstrates use of the Wire library
// Reads data from an I2C/TWI slave device
// Refer to the "Wire Slave Sender" example for use with this
// This example code is in the public domain.
#include <Wire.h>
#include <PolledTimeout.h>
#define SDA_PIN 4
#define SCL_PIN 5
const int16_t I2C_MASTER = 0x42;
const int16_t I2C_SLAVE = 0x08;
Serial.begin(115200); // start serial for output
Wire.begin(SDA_PIN, SCL_PIN, I2C_MASTER); // join i2c bus (address optional for master)
using periodic = esp8266::polledTimeout::periodic;
static periodic nextPing(1000);
if (nextPing) {
Wire.requestFrom(I2C_SLAVE, 6); // request 6 bytes from slave device #8
while (Wire.available()) { // slave may send less than requested
char c = Wire.read(); // receive a byte as character
Serial.print(c); // print the character
Code on Uno
#include <Wire.h>
Wire.begin();
while (!Serial); // Leonardo: wait for serial monitor
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknown error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
I did everything and I still can't get it to be picked up by a wire scanner! I tried both the ESP8266 and ESP32S and made sure I set pins correctly. Still, no go. It only finds the LCD at 0x27. I even am using a LLC so voltages are properly shifted. I've been working on this for hours trying new pins, flipping SDA and SCL, tried disconnecting the LCD, etc... please help me.
14:58:23.670 -> Scanning I2C Addresses
14:58:23.670 -> .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
14:58:23.704 -> .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
14:58:23.704 -> .. .. .. .. .. .. .. 27 .. .. .. .. .. .. .. ..
14:58:23.737 -> Scan Completed, 1 I2C Devices found.
14:58:23.737 ->
14:58:23.737 -> Discovering eeprom sizes 0x50..0x57
14:58:23.805 -> 0x50: Not Present.
14:58:23.941 -> 0x51: Not Present.
14:58:24.009 -> 0x52: Not Present.
14:58:24.110 -> 0x53: Not Present.
14:58:24.211 -> 0x54: Not Present.
14:58:24.312 -> 0x55: Not Present.
14:58:24.413 -> 0x56: Not Present.
14:58:24.515 -> 0x57: Not Present.
I know, I'm using master reader to setup the ESP32S with pins 21 and 22 but still no luck.
mattlogue:
i2c scanner can run only on master
Here is what I'm using. Is this appropriate to scan from an Uno to find an ESP?
Also, when ran on the ESP, i2cScanner reports Zero devices (doesn't see Uno or LCD). I have the thing hooked up on Uno side on pins A4/5 and past two pullup resistors, then into LLC -> 3.3V then into pins 21 and 22 on the ESP32S. The LCD is hooked up to Uno pins SDA/SCL. What on earth am I doing wrong?
/* I2C slave Address Scanner
for 5V bus
* Connect a 4.7k resistor between SDA and Vcc
* Connect a 4.7k resistor between SCL and Vcc
for 3.3V bus
* Connect a 2.4k resistor between SDA and Vcc
* Connect a 2.4k resistor between SCL and Vcc
#include <Wire.h>
void scan(){
Serial.println(" Scanning I2C Addresses");
uint8_t cnt=0;
for(uint8_t i=0;i<128;i++){
Wire.beginTransmission(i);
uint8_t ec=Wire.endTransmission(true);
if(ec==0){
if(i<16)Serial.print('0');
Serial.print(i,HEX);
cnt++;
else Serial.print("..");
Serial.print(' ');
if ((i&0x0f)==0x0f)Serial.println();
Serial.print("Scan Completed, ");
Serial.print(cnt);
Serial.println(" I2C Devices found.");
bool i2cReady(uint8_t adr){
uint32_t timeout=millis();
bool ready=false;
while((millis()-timeout<100)&&(!ready)){
Wire.beginTransmission(adr);
ready=(Wire.endTransmission()==0);
return ready;
void eepromSize(){
Serial.println("Discovering eeprom sizes 0x50..0x57");
uint8_t adr=0x50,i;
uint16_t size;
char buf[64];
while(adr<0x58){
i=0;
size = 0x1000; // Start at 4k
i += sprintf_P(&buf[i],PSTR("0x%02X: "),adr);
if(i2cReady(adr)) { // EEPROM answered
uint8_t zeroByte;
Wire.write((uint8_t)0); // set address ptr to 0, two bytes High
Wire.write((uint8_t)0); // set address ptr to 0, two bytes Low
uint8_t err=Wire.endTransmission();
if(err==0){// worked
err=Wire.requestFrom(adr,(uint8_t)1);
if(err==1){// got the value of the byte at address 0
zeroByte=Wire.read();
uint8_t saveByte,testByte;
do{
if(i2cReady(adr)){
Wire.write(highByte(size)); // set next test address
Wire.write(lowByte(size));
if(err==1){
saveByte=Wire.read();
Wire.write((uint8_t)~zeroByte); // change it
if(err==0){ // changed it
if(!i2cReady(adr)){
i+=sprintf_P(&buf[i],PSTR(" notReady2.\n"));
Serial.print(buf);
adr++;
Wire.write((uint8_t)0); // address 0 byte High
Wire.write((uint8_t)0); // address 0 byte Low
if(err==0){
if(err==1){ // now compare it
testByte=Wire.read();
else {
testByte=~zeroByte; // error out
else {
testByte=~zeroByte;
else {
testByte = ~zeroByte;
//restore byte
if(!i2cReady(adr)){
i+=sprintf_P(&buf[i],PSTR(" notReady4.\n"));
Serial.print(buf);
adr++;
Wire.write((uint8_t)saveByte); // restore it
else testByte=~zeroByte;
if(testByte==zeroByte){
size = size <<1;
}while((testByte==zeroByte)&&(size>0));
if(size==0) i += sprintf_P(&buf[i],PSTR("64k Bytes"));
else i+=sprintf_P(&buf[i],PSTR("%dk Bytes"),size/1024);
if(!i2cReady(adr)){
i+=sprintf_P(&buf[i],PSTR(" notReady3.\n"));
Serial.print(buf);
adr++;
continue;
Wire.write(zeroByte); //Restore
else i+=sprintf_P(&buf[i],PSTR("Read 0 Failure"));
else i+=sprintf_P(&buf[i],PSTR("Write Adr 0 Failure"));
else i+=sprintf_P(&buf[i],PSTR("Not Present."));
Serial.println(buf);
adr++;
void setup(){
Wire.begin();
scan();
eepromSize();
void loop(){}
Now it can find the LCD THRU the Uno, but not the Uno itself! How weird is that? That confirms the pins are right.
I nedd to learn difference between i2c slave and master.
I can't even get wire working from an ESP8266 to an ESP32. I put the scanner (master mode) on the ESP32 and it does not find anything although a ESP8266 is connected.
mattlogue:
it is a bus. master can find slaves on the bus. A4 is SDA and A5 is SCL. this Uno pins are wired together.
do you run Wire library in slave mode in Uno?
I got it working for a second on the ESP32 with wire slave on Uno, but when I changed to ESP8266 it couldn't find the uno.
Esp are 3.3V. Uno is 5V. Maybe you need to use logic level converters.
I had a defective LLC I think. Halfway through my testing last night I stopped using it. I also tend to think an LLC protects the ESP more than it facilitates communication. I may try using another LLC, kind of gave up on Wire and went back to Serial for time being. Wire isn't easy to get working, that's for damned sure.
