Can't find out how to change my pin
in my programme the flowmeter sensor and my gsm board are on the same pin but i can find how to change it (wen i put my flowmeter pin on 6 it donsen’t work any more)
int hallsensor = 6;    //The pin location of the sensor
So i can’t find out how to change my pin…
here is my programme. I wil be thank’s full for anny help o/
// include the GSM library
#include <GSM.h>
// PIN Number for the SIM
#define PINNUMBER "1234"
// initialize the library instances
GSM gsmAccess;
GSM_SMS sms;
// Array to hold the number a SMS is retreived from
char senderNumber[20];
char remoteNum[20]="+33698513237";
char txtMsgFix[200]="Nous avons debloque l'elecrovanne a votre demande !";
char txtMsg[200]="Votre arrive d'eau a etait bloque, car un probleme a etait detecte !";
volatile int NbTopsFan; //measuring the rising edges of the signal
int Calc;
int hallsensor = 2;    //The pin location of the sensor
int sec=0;
int SecVariable=0;
int ledPin = 13;
int Nbloquage=0;
int c = 0;
int vanne = 4;
void rpm ()     //This is the function that the interupt calls
  NbTopsFan++;  //This function measures the rising and falling edge of the hall effect sensors signal
   pinMode(hallsensor, INPUT); //initializes digital pin 2 as an input
   Serial.begin(9600); //This is the setup function where the serial port is initialised,
   attachInterrupt(0, rpm, RISING); //and the interrupt is attached
   pinMode(vanne, OUTPUT);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("SMS Messages Reception");
  // connection state
  boolean notConnected = true;
  // Start GSM connection
  while (notConnected)
    if (gsmAccess.begin(PINNUMBER) == GSM_READY)
      notConnected = false;
      Serial.println("Non connecte");
  Serial.println("GSM initialise");
  Serial.println("Attentes des messages...");
void loop ()
   digitalWrite(vanne, HIGH);
   NbTopsFan = 0;   //prépart NbTops pour le calcule
   sei();      //Enables interrupts
   delay(100);   //+0.1sc
   cli();      //Disable interrupts
   Calc = (NbTopsFan * 60 / 7.5); //(Pulse frequency x 60) / 7.5Q, = flow rate in L/hour
   Serial.print (Calc, DEC); //Prints the number calculated above
  Serial.print (" L/hour\r\n"); //Prints "L/hour" and returns a  new line
if (Calc > 0) //peut être remplacer “0” après des test par un chiffre + grand.
   delay(8000);
   sec=sec+1;    // + 1sc de le débit coule + le delay(1000) au début do void loop
     if (sec>160)
     digitalWrite(vanne, LOW);
     delay(12000000);
     if (Nbloquage=1)
       sms.beginSMS(remoteNum);
       sms.print(txtMsg);
       sms.endSMS();
       Serial.println("\nMessage Probleme envoye\n");
       // gsm envoie un sms
       // si reçois relancer le débit via gsm "Nbloquage=-1;"
        sec=0;
     Nbloquage=Nbloquage+1;
  delay(8000);
  sec=sec-1;
  c=c+1;
  if (sec=0) c=0;
  if (c>40)
    sec=0;
    SecVariable=0;
  SecVariable=SecVariable+1;
  if (Nbloquage+1>200)
    //electrovanne (12v) bloquer
     if (Nbloquage=1)
        // si reçois relancer le débit via gsm "y=-1;"
Looking at your code, hallsensor has to be on an interrupt pin (say either 2 or 3 on an arduino uno). If pin 3 is available, set hallsensor to 3 and change the line
to
attachInterrupt(1, rpm, RISING); //and the interrupt is attached
6v6gt: attachInterrupt(1, rpm, RISING); //and the interrupt is attached
Would do better to let the software work out which interrupt to use i.e.
attachInterrupt(digitalPinToInterrupt(hallsensor), rpm, RISING); //and the interrupt is attached
stowite:
That would be even better. And while he is at it, he should also change his PIN code from 1234 now that we all know it !
