Can't find the bug...
Hi
so, i’m writing this program to basically “debounce” two sets of 2 contact switches. this debounced is very based on the example provided.
I set the debounce time for 1 sec, just for testing, as it gets better, i wanna get it as low as i can. The program works just fine for a while, but then it suddendly starts showing new results every millisecond. In it’s core, i shouls only get a new message every second or so, so something is really messed up, the problem is, i can’t seem to find out what is wrong… Can anyone help me please? Thank you
below is the coding:
#include <Servo.h>
Servo myservo[2]; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
int a;
int b;
int doit=0;
byte Pin1[2]={4, 6};
byte Pin2[2]={5, 7};
int currentreading[2];
int lastreading[2];
int time[2] ={0, 0};
int val[2];
myservo[0].attach(10); // attaches the servo on pin 9 to the servo object
myservo[1].attach(11);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
for (byte i=0; i < 2; i++){
pinMode(Pin1*, INPUT);*
_ pinMode(Pin2*, INPUT);_
_ digitalWrite(Pin1, HIGH);
digitalWrite(Pin2, HIGH);}
//End for*
*} *_
* int rot;*
* for (int i=0; i < 2; i++){*
* UpdateRot(i);*
_ rot=val*;*_
_ if (rot==1) myservo*.write(84);
else{
if (rot>2) myservo.write(0);
else myservo.write(180);}}
if (doit==1) {
Serial.print(val);*
Serial.print(" ");}_
_ Serial.println(" ");
doit=0;
delay(10);
void UpdateRot(byte IClaw) {
currentreading[IClaw]=GetAngle(IClaw);
if (currentreading[IClaw]!=lastreading[IClaw]) {
time[IClaw]=millis();
lastreading[IClaw]=currentreading[IClaw];}*_
* if ((millis()-time[IClaw])>1000){*
* if (lastreading[IClaw]!=val[IClaw]){*
* val[IClaw]=lastreading[IClaw];*
* doit=1;*
int GetAngle(byte IClaw) {
* // 11=1 10=2 00=3 01=4*
* a=digitalRead(Pin1[IClaw]);*
* b=digitalRead(Pin2[IClaw]);*
// Serial.print(a);
* //Serial.print(" - ");*
* // Serial.print(b);*
* //Serial.print(" : ");*
* if (a==1) return (2-b);*
* else return (b+3);*
* } //End GetAngle*
[/quote]
 pinMode(Pin1, INPUT);
A subscript is required for arrays
Weird as it may seem, in my coding, on the arduino program, the parenthesis with the i are there... somehow, when i copied, they didn't show up...
Any ideas?
And the type returned by millis is?
Thank you. That must have been the problem, i changed int to unsigned long, and it works now. Thanks very much
