Can't find the cause of this thing
So I made a this in TinkerCAD:
The code inside the Adruino Uno:
#include <IRremote.h>
#include <LiquidCrystal.h>
//----Variables-----\\
const int RedPin = 11;
const int GreenPin = 9;
const int BluePin = 10;
const int IRrecvPin = 12;
int ColourRed = 255;
int ColourGreen = 255;
int ColourBlue = 255;
int WhichMode = 0;
boolean LCDPressOn = false;
boolean LEDOn = false;
String CurrentColour[8] = {"w", "r", "g", "b", "o", "y", "a", "p"};
int ColourTracker = 0;
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);     // Initialize the LCD Pins
IRrecv irrecv(IRrecvPin);	//Start the IR
decode_results results;		//Start the IR
unsigned long key_value = 0;
//---Custom-Characters---\\
byte PowerButton[8] = {
  B00000,
  B00100,
  B01110,
  B10101,
  B10001,
  B10001,
  B01110,
  B00000
//-----Start-Once-----\\
void setup(){
  pinMode(BluePin, OUTPUT);
  pinMode(RedPin, OUTPUT);
  pinMode(GreenPin, OUTPUT);
  lcd.begin(16, 2);
  lcd.createChar(2, PowerButton);
  irrecv.enableIRIn();
  irrecv.blink13(true);
//-------Repeat-------\\
void loop(){
  TranslateIR();
  LCD();
//---LCD---\\
void LCD() {
  if (LEDOn && LCDPressOn == false && WhichMode == 0){
    lcd.setCursor(0, 0);
  	lcd.print("    LED On      ");
  	lcd.setCursor(0, 1);
    lcd.print("                ");
    LCDPressOn = true;
  } else if (LEDOn && LCDPressOn && WhichMode == 0) {
	lcd.print(" Current Values ");
	lcd.print("RGB= ");
	lcd.print(ColourRed);
	lcd.print(",");
	lcd.print(ColourGreen);
	lcd.print(",");
	lcd.print(ColourBlue);
  } else if (LEDOn == false && WhichMode == 0) {
  	lcd.print("    LED Off     ");
    lcd.print("    Press ");
    lcd.setCursor(10, 1);
    lcd.write(2);
    lcd.setCursor(11, 1);
    lcd.print("   ");
  } else if (LEDOn && WhichMode == 1) { // Red
    lcd.print("(-/+)        Red");
    lcd.print("Value = ");
  } else if (LEDOn && WhichMode == 2) { // Green
    lcd.print("(-/+)      Green");
  } else if (LEDOn && WhichMode == 3) { // Blue
    lcd.print("(-/+)       Blue");
  } else if (LEDOn && WhichMode == 4) { // Default
    WhichMode = 0;
    LCDPressOn = true;
//---Change-Values-RGB---\\
void ChangeValueN() {
  if (LEDOn) {
    if (WhichMode == 1) {
      ColourRed = ColourRed - 10;
      if (ColourRed < 0) ColourRed = 0;
      analogWrite(RedPin, ColourRed);
      analogWrite(GreenPin, ColourGreen);
      analogWrite(BluePin, ColourBlue);
    } else if (WhichMode == 2) {
      ColourGreen = ColourGreen - 10;
      if (ColourGreen < 0) ColourGreen = 0;
    } else if (WhichMode == 3) {
      ColourBlue = ColourBlue - 10;
      if (ColourBlue < 0) ColourBlue = 0;
void ChangeValueP() {
  if (LEDOn) {
      ColourRed = ColourRed + 10;
      if (ColourRed > 255) ColourRed = 255;
      ColourGreen = ColourGreen + 10;
      if (ColourGreen > 255) ColourGreen = 255;
      ColourBlue = ColourBlue + 10;
      if (ColourBlue > 255) ColourBlue = 255;
//-----Set-LED-----\\
void SetLED() {
  if (CurrentColour[ColourTracker].equals("w")) {
    ColourRed = 255;
	ColourGreen = 255;
	ColourBlue = 255;
    if (LEDOn) {
  } else if (CurrentColour[ColourTracker].equals("r")) {
    ColourRed = 255;
	ColourGreen = 0;
	ColourBlue = 0;
    if (LEDOn) {
  } else if (CurrentColour[ColourTracker].equals("g")) {
    ColourRed = 0;
	ColourGreen = 255;
	ColourBlue = 0;
    if (LEDOn) {
  } else if (CurrentColour[ColourTracker].equals("b")) {
    ColourRed = 0;
	ColourGreen = 0;
	ColourBlue = 255;
    if (LEDOn) {
  } else if (CurrentColour[ColourTracker].equals("o")) {
    ColourRed = 255;
	ColourGreen = 69;
	ColourBlue = 0;
    if (LEDOn) {
  } else if (CurrentColour[ColourTracker].equals("y")) {
    ColourRed = 255;
	ColourGreen = 255;
	ColourBlue = 0;
    if (LEDOn) {
  } else if (CurrentColour[ColourTracker].equals("a")) {
    ColourRed = 0;
	ColourGreen = 255;
	ColourBlue = 255;
    if (LEDOn) {
  } else if (CurrentColour[ColourTracker].equals("p")) {
    ColourRed = 255;
	ColourGreen = 0;
	ColourBlue = 255;
    if (LEDOn) {
//-----Toggle-LED-----\\
void ToggleLED() {
  if (LEDOn) {
    Serial.println("LED turned off");
    analogWrite(RedPin, 0);
    analogWrite(GreenPin, 0);
    analogWrite(BluePin, 0);
    LEDOn = false;
    delay(200);
    Serial.println("LED turned on");
    LEDOn = true;
    delay(200);
//----Cycle----\\
void Cycle() {
  if (LEDOn) {
    ColourTracker++;
    if (ColourTracker > 7 || ColourTracker < 0) {
      ColourTracker = 0;
//---Cycle-Modes---\\
void CycleMode() {
  if (LEDOn){
    WhichMode++;
    if (WhichMode > 4 || WhichMode < 0) {
      WhichMode = 0;
//-----Translate-IR----\\
void TranslateIR() {
  if (irrecv.decode(&results)){
    if (results.value == 0XFFFFFFFF) results.value = key_value;
    switch(results.value) {
    	case 0xFD00FF:
      		Serial.println("POWER");
      		lcd.clear();
      		ToggleLED();
      	case 0xFD40BF:
          	Serial.println("FUNC/STOP");
      		lcd.clear();
      		Cycle();
      		SetLED();
      	case 0xFDA05F:
      		Serial.println(">||");
      		lcd.clear();
      		CycleMode();
      	case 0xFD20DF:
      		Serial.println("|<<");
      		lcd.clear();
      		ChangeValueN();
      		delay(100);
      	case 0xFD609F:
      		Serial.println(">>|");
      		lcd.clear();
      		ChangeValueP();
      		delay(100);
    Serial.println(results.value);
    key_value = results.value;
    irrecv.resume();
So my problem is that when I cycle through the modes (by pressing pause button) and decrease or increase the values of the colours (by pressing |<< or >>| buttons), only the blue and green work, but the red doesn't and I can't figure the problem out.
Edit: When I press |<< then the code for all buttons change randomly. But only when the mode is on the red and then I press |<<.
add serial-output that shows the values of each variable in every iteration
here is your code more formatted
Did you really want a part of the lines to be outside the innermost if-conditions
int WhichMode = 0;
  B00000,
  B00100,
  B01110,
  B10101,
  B10001,
  B10001,
  B01110,
  B00000
  lcd.begin(16, 2);
  TranslateIR();
  LCD();
//---LCD---\\
void LCD() {
  if (LEDOn && LCDPressOn == false && WhichMode == 0) {
    lcd.print("                ");
    LCDPressOn = true;
    lcd.print("RGB= ");
    lcd.print(",");
    lcd.print(",");
    lcd.write(2);
    lcd.print("   ");
    WhichMode = 0;
    LCDPressOn = true;
  if (LEDOn) {
      if (ColourRed < 0) {
        ColourRed = 0;
      if (ColourGreen < 0) {
        ColourGreen = 0;
      if (ColourBlue < 0) {
        ColourBlue = 0;
  if (LEDOn) {
      if (ColourRed > 255) {
        ColourRed = 255;
      if (ColourGreen > 255) {
        ColourGreen = 255;
      if (ColourBlue > 255) {
        ColourBlue = 255;
void SetLED() {
    ColourRed = 255;
    ColourGreen = 255;
    ColourBlue = 255;
    if (LEDOn) {
    ColourRed = 255;
    ColourGreen = 0;
    ColourBlue = 0;
    if (LEDOn) {
    ColourRed = 0;
    ColourGreen = 255;
    ColourBlue = 0;
    if (LEDOn) {
    ColourRed = 0;
    ColourGreen = 0;
    ColourBlue = 255;
    if (LEDOn) {
    ColourRed = 255;
    ColourGreen = 69;
    ColourBlue = 0;
    if (LEDOn) {
    ColourRed = 255;
    ColourGreen = 255;
    ColourBlue = 0;
    if (LEDOn) {
    ColourRed = 0;
    ColourGreen = 255;
    ColourBlue = 255;
    if (LEDOn) {
    ColourRed = 255;
    ColourGreen = 0;
    ColourBlue = 255;
    if (LEDOn) {
void ToggleLED() {
  if (LEDOn) {
    LEDOn = false;
    delay(200);
  else {
    LEDOn = true;
    delay(200);
//----Cycle----\\
void Cycle() {
  if (LEDOn) {
    ColourTracker++;
      ColourTracker = 0;
void CycleMode() {
  if (LEDOn) {
    WhichMode++;
      WhichMode = 0;
  if (irrecv.decode(&results)) {
    switch (results.value) {
      case 0xFD00FF:
        lcd.clear();
        ToggleLED();
      case 0xFD40BF:
        lcd.clear();
        Cycle();
        SetLED();
      case 0xFDA05F:
        lcd.clear();
        CycleMode();
      case 0xFD20DF:
        lcd.clear();
        ChangeValueN();
        delay(100);
      case 0xFD609F:
        lcd.clear();
        ChangeValueP();
        delay(100);
    irrecv.resume();
what do you mean by outside the innermost if-conditions. I am new to C++ and very bad at english.
what prevents TranslateIR() calling the function multiple times? is there a mechanism to recognize that a code has been received and won't be processes again until no code is received? not sur ehow the IR decoder works
in CycleMode(), shouldn't WhichMode be set to 1 when incremented > 3, not 4?
No, it should be set to 0 so it will change the menu to the default and if it turn to 1 then it change to the red menu
Each "if" statement contains code that is inside brackets. i.e. { code }
so outside the if statement means the adding code that is before the { or after the }
That's not the problem. its nothing to do with the if statement. The problem is that when the mode is on red and I decrease the value of red all the codes for the buttons in the IR Remote change to something else.
It is likely that you didn't set curly braces around a part of the if-conditions
This means a part of the commands is executed unconditional
