Can't find the file in the directory in the directory where the file was found
Had a host of other anomalies akin to this, which seemed to go away after a reinstall. This I’m lost on…
Arduino: 1.6.6 (Windows 7), Board: “Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)”
Unable to find C:\Program Files (x86)\Arduino\skimmer_2\skimmer_2.ino in C:\Program Files (x86)\Arduino\skimmer_2
Error compiling.
“Show verbose output during compilation”
enabled in File > Preferences.
Why is your sketch folder in C:\Program Files (x86)?
Why have you "upgraded" to the bleeding edge (i.e. not adequately tested) version of the IDE for a board that was perfectly well served by the 1.0.x versions of the IDE?
The code you are trying to compile?
Suggestion, make a folder called
C:\Arduino Projects
And store ALL your projects in it.
Any Library file I placed in MyDocuments/Arduino/Lib it should already exist, made when the IDE was installed.
That way it is accessible by all versions of the IDE.
Tom.... :)
Trying all of the above. Thanks
Hi, Sorry..
MyDocuments/Arduino/libraries
Not lib
Tom...... :o
