DanDare
November 26, 2010, 4:57pm
1
Hello,
Im trying a very simple sketch but can't understand the logic behind this failure:
If I execute:
const int nav = 8 ;
String selecopt = "Default";
long previousMillis = 0;
pinMode(nav, INPUT);
pinMode(13, OUTPUT);
void loop () {
if(digitalRead(nav) == HIGH) { String selecopt = "Cmon" ; digitalWrite(13, HIGH); }
if ( (millis() - previousMillis > 1000)) { previousMillis = millis(); Serial.println(selecopt); }
When I press the button, the led goes light but serial monitor wont show me "Cmon" but just "Default", no matter how many times i hit digital input on pin 13.
But if I run the code:
const int nav = 8 ;
void loop () {
if(digitalRead(nav) == HIGH) { digitalWrite(13, HIGH); }
"Cmon" is the only thing that is show on serial monitor, naturally.
Why it doesnt work inside the IF statement as led does?
What am I missing here?
Appreciate any clue.
Rodrigo
system
November 26, 2010, 5:06pm
2
Here you have a global variable.
Those open and close curly braces define the scope of the selecopt (local) variable. It ceases to exist after the }, so the global (unmodified) variable is now accessible.
Try losing the String variable declaration in the if block. Then, the global variable will be modified.
DanDare
November 26, 2010, 5:15pm
3
Thanks PaulS to bring some logic to the problem. So if I redeclare the string under main loop section it works, otherwise it doesnt.
How to lose the string variable and redeclare inside the IF statement?
Edited ====
I mean: I like to redeclare the global variable inside the IF statement
Edited ====
Thanks,
Rodrigo
system
November 26, 2010, 5:25pm
4
{ selecopt = "Cmon" ; digitalWrite(13, HIGH); }
Just delete the word String. It's presence is what is causing the creating of a local variable with the same name as the global variable.
DanDare
November 26, 2010, 5:28pm
5
Ahhh great.... thank you.
Weird because its just the usual way to redeclare variables.
It's me just trying String for the first time and I may be mind blocked or something.
Thanks PaulS
