Can't find this board in the setup menu
Hi. I have some of these "UNO" boards, but they don't respond to the setup. Can anyone tell me either what they are, or at least what board I should pick from the "Tools" menu?
Thank you!
What’s the chip near the USB connector? CH340 or similar? You might need to start with getting a driver working for it, test with the Loopback test: Reset to Gnd, connect D0 to D1, see if stuff typed in the Serial Monitor is repeated back…
The bottom of the board says USB-TTL CH340G, you will need a driver for this.
It also says:
MCU-Atmega328P
WIFI-ESP8266+ There is a jack for the antenna.
