hey so I’m following a tutorial but I’m constantly getting new errors so far I’ve been able to fix them but i can’t get past this now any help is appreciated.
Code:
void DisplayStyle1 () {
//--------------------------------------- Display Background ----------------------------------------------------
/* OLED Background */
display.setTextSize(2); //set background txt font size
display.setCursor(1, 12);
display.println("CPU");
display.setCursor(1, 38);
display.println("GPU");
display.setTextSize(1); //set background txt font size
display.setCursor(1, 56);
display.println("SYSRAM");
//display.display();
//oledDraw = 1;
/*CPU/GPU/RAM Clearing Boxes, eg: display.fillRect(<X>, ^Y^, W, H, Color);*/
display.fillRect(38, 11, 90, 16, BLACK); // fill CPU live stats section only
display.fillRect(38, 37, 90, 16, BLACK); // fill GPU live stats section only
display.fillRect(38, 54, 36, 10, BLACK); // fill RAM live stats section only
/* Position Test*/
//display.drawRect(38, 11, 90, 16, WHITE); // fill CPU live stats section only
//display.drawRect(38, 37, 90, 16, WHITE); // fill GPU live stats section only
//display.drawRect(38, 54, 36, 10, WHITE); // fill RAM live stats section only
//display.drawRect(68, 54, 58, 10, WHITE); // Flash bottom right corner when updating
//---------------------------------------CPU & GPU Hardware ID----------------------------------------------------
/*CPU & GPU Hardware ID*/
/*CPU Manual Position Test*/
//display.setTextSize(0);
//display.setCursor(-35, 1);// Negative spacing so, CPU ID doesn't cause a rollover, on the next line
//String cpuName = "Intel Core i7-5820K"; // Name spacing test
display.setTextSize(0); // string font size
String cpuName = "";
display.println(cpuName);
/* GPU Manual Position Test*/
//display.setCursor(-42, 28); // Negative spacing so, GPU ID doesn't cause a rollover, on the next line
//String gpuName = "Nvidia GeForce GTX 1080"; // Name spacing test
String gpuName = "";
display.println(gpuName);
if (inputString.indexOf("CPU") > -1)
display.setCursor(0, 1);
int cpuNameStart = inputString.indexOf("CPU:");
if (inputString.indexOf("Intel", cpuNameStart) > -1) {
cpuNameStart = cpuNameStart + 10;
else {
cpuNameStart = cpuNameStart + 8;
if (inputString.indexOf("GPU") > -1)
cpuName = inputString.substring(cpuNameStart, inputString.indexOf("GPU:"));
cpuName = inputString.substring(cpuNameStart);
display.setCursor(0, 28);
//display.setCursor(-41, 28); // Negative spacing so, Nvidia doesn't cause a rollover, on the next line
int gpuNameStart = inputString.indexOf("GPU:");
if (inputString.indexOf("NVIDIA", gpuNameStart) > -1) {
gpuNameStart = gpuNameStart + 11;
else {
gpuNameStart = gpuNameStart + 8;
int gpuNameEnd = inputString.indexOf("|", gpuNameStart);
String gpuName = inputString.substring(gpuNameStart, gpuNameEnd);
//------------------------------------------ CPU Load/Temp -------------------------------------------------
/*CPU Display String*/
int cpuStringStart = inputString.indexOf("C");
int cpuDegree = inputString.indexOf("c");
int cpuStringLimit = inputString.indexOf("|");
String cpuString1 = inputString.substring(cpuStringStart + 1, cpuDegree);
String cpuString2 = inputString.substring(cpuDegree + 1, cpuStringLimit - 1);
/*CPU TEMPERATURE*/
display.setCursor(42, 12);
display.print(cpuString1);
#ifdef noDegree
display.print("C"); // Centigrade Symbol
#else
display.print((char)247); //Degrees Symbol
#endif
/*CPU LOAD, ALL CORES*/
display.print(cpuString2);
display.println("%"); // Small Percent Symbol
//------------------------------------------ GPU Load/Temp -------------------------------------------------
/*GPU Display String*/
int gpuStringStart = inputString.indexOf("G", cpuStringLimit);
int gpuDegree = inputString.indexOf("c", gpuStringStart);
int gpuStringLimit = inputString.indexOf("|", gpuStringStart);
String gpuString1 = inputString.substring(gpuStringStart + 1, gpuDegree);
String gpuString2 = inputString.substring(gpuDegree + 1, gpuStringLimit - 1);
/*GPU TEMPERATURE*/
display.setCursor(42, 38);
display.print(gpuString1);
#ifdef noDegree
#else
#endif
/*GPU LOAD*/
display.print(gpuString2);
//----------------------------------------SYSTEM RAM USAGE---------------------------------------------------
/*SYSTEM RAM String*/
int ramStringStart = inputString.indexOf("R", gpuStringLimit);
int ramStringLimit = inputString.indexOf("|", ramStringStart);
String ramString = inputString.substring(ramStringStart + 1 , ramStringLimit);
/*RAM USAGE*/
display.setCursor(42, 56);
display.println(ramString);
display.setCursor(115, 1);
display.println("D1");
display.display();
oledDraw = 1;
Errors:
Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Users\Alex\AppData\Local\Temp\Temp2_GnatStats Release v1.2.zip\GnatStats Release v1.2\Arduino_GNAT_STATS_OLED_V1.2\DisplayStyle1\DisplayStyle1.ino: In function 'void DisplayStyle1()':
DisplayStyle1:12: error: 'display' was not declared in this scope
DisplayStyle1:26: error: 'BLACK' was not declared in this scope
DisplayStyle1:57: error: 'inputString' was not declared in this scope
DisplayStyle1:80: error: 'inputString' was not declared in this scope
DisplayStyle1:103: error: 'inputString' was not declared in this scope
DisplayStyle1:178: error: 'oledDraw' was not declared in this scope
oledDraw = 1;
exit status 1
option enabled in File -> Preferences.
