Can't Flash Bootloader on ATMEGA328-MMH in 1.8.16
I have a custom ATMEGA328-MMH board, and I'm flashing it using an Atmel-ICE programmer.
I'm running Arduino 1.8.16, and have the Minicore boards project pulled into my IDE to flash the ATMEGA328.
I can flash applications just fine, but fail to flash the bootloader.
I don't even actually want the Arduino bootloader, I just want to use the "Burn Bootloader" function to program the fuses I need (specifically removing the default clock divider).
Yes, I know that I can do this on the command line using avrdude. This project is for a colleague who will NOT be comfortable using avrdude on the command line.
Anyway here's what I get when I Burn Bootloader:
Arduino: 1.8.16 (Windows Store 1.8.51.0) (Windows 10), Board: "ATmega328, No bootloader, EEPROM not retained, 328 / 328A, BOD 2.7V, LTO disabled, Internal 8 MHz"
C:\Users\ME\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino18/bin/avrdude -CC:\Users\ME\Documents\ArduinoData\packages\MiniCore\hardware\avr\2.1.3/avrdude.conf -v -patmega328 -catmelice_isp -Pusb -e -Ulock:w:0x3f:m -Uefuse:w:0b11111101:m -Uhfuse:w:0b11011111:m -Ulfuse:w:0xe2:m
avrdude: Version 6.3-20201216
     Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\ME\Documents\ArduinoData\packages\MiniCore\hardware\avr\2.1.3/avrdude.conf"
     Using Port                    : usb
     Using Programmer              : atmelice_isp
avrdude: Found CMSIS-DAP compliant device, using EDBG protocol
     AVR Part                      : ATmega328
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : JTAG3_ISP
     Description     : Atmel-ICE (ARM/AVR) in ISP mode
     Vtarget         : 4.9 V
     SCK period      : 8.00 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9514 (probably m328)
avrdude: erasing chip
avrdude: reading input file "0x3f"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3f:
avrdude: load data lock data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
avrdude: reading on-chip lock data:
avrdude: verifying ...
avrdude: WARNING: invalid value for unused bits in fuse "lock", should be set to 1 according to datasheet
This behaviour is deprecated and will result in an error in future version
You probably want to use 0xff instead of 0x3f (double check with your datasheet first).
avrdude: 1 bytes of lock verified
avrdude: reading input file "0b11111101"
avrdude: writing efuse (1 bytes):
Error while burning bootloader.
Writing | ################################################## | 100% 0.09s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0b11111101:
avrdude: load data efuse data from input file 0b11111101:
avrdude: input file 0b11111101 contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: verification error, first mismatch at byte 0x0000
     0xff != 0xfd
avrdude: verification error; content mismatch
avrdude done. Thank you.
I did a lot of searching around and found a few breadcrumbs. It looks like it may have been addressed back in 1.6.12 but I'm still seeing the issue above and unsure of next steps. I can brute force the fuses in Microchip Studio but this again will not be acceptable for the end user.
Interestingly enough, if I go to my command line and paste just the raw avrdude command, it works:
Anyone?
Aaaand anyone?
Looks like this avrdude “bug”?
Thanks! Really appreciate it. Looks like we'll need to wait for an avrdude release.
