Can't get actual output when, both input logic is high
Can't get actual output when, both input logic is high. Please help me, if any modification on this code.
pinMode(8,OUTPUT);
pinMode(12,OUTPUT);
pinMode(2, INPUT);
pinMode(4, INPUT);
int light = digitalRead(2);
int ir = digitalRead(4);
if (light == LOW && ir == LOW)
digitalWrite(8, HIGH);
digitalWrite(12, LOW);
delay(2000);
if (light == LOW && ir == HIGH)
digitalWrite(12, HIGH);
delay(2000);
digitalWrite(8, LOW);
delay(2000);
delay(2000);
Where are you testing when both are HIGH ?
Here is your code auto formatted in the IDE and posted here in code tags
Please do the same in future
  pinMode(8, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(2, INPUT);
  pinMode(4, INPUT);
    delay(2000);
    delay(2000);
    delay(2000);
  delay(2000);
I tested in two DC motor
Where in your code are you testing when both are HIGH ?
Have you tried printing the values that you are testing ?
Are they what you expect ?
Please find the code now. I want
When,
light=0, ir=0 then output will pin 8 high & pin 12 low
light=0, ir=1 then output will pin 8 high & pin 12 high
light=1, ir=0 then output will pin 8 low & pin 12 low
light=1, ir=1 then output will pin 8 low & pin 12 low (This statement does not work)
pinMode(8,OUTPUT);
pinMode(12,OUTPUT);
pinMode(2, INPUT);
pinMode(4, INPUT);
delay(2000);
delay(2000);
if (light == HIGH && ir == LOW)
delay(2000);
if (light == HIGH && ir == HIGH)
delay(2000);
delay(2000);
Still no code tags or formatting to make your code easier to read and copy
The same output for different input conditions ?
Is that right ? If so, then why test ir when light is HIGH ?
UKHeliBob:
Sorry for no code tag.
Yes, same output for different input conditions.
Can you suggest me any modification?
Try this (untested)
  pinMode(8, OUTPUT);
  pinMode(2, INPUT);
  pinMode(4, INPUT);
  byte light = digitalRead(2);
  byte ir = digitalRead(4);
  if (light == LOW)
    if (ir == LOW)
    delay(2000);
    delay(2000);
  delay(2000);
UKHeliBob:
Try this (untested)
    delay(2000);
  delay(2000);
When logic, light=high & ir=low the else statement works perfectly.
But, when light=high & if=high. It does not work as previous.
My code does not work properly when both input is high (light=1 & ir=1)
Please find the code. I want
When,
Please help me. If any modification needed.
pinMode(8,OUTPUT);
pinMode(12,OUTPUT);
pinMode(2, INPUT);
pinMode(4, INPUT);
delay(2000);
delay(2000);
delay(2000);
delay(2000);
delay(2000);
how can you tell the difference between the last 2 cases: light == 1 and ir == 0/1 since the outputs are the same in both cases: 0,0?
Topics merged
Why did you start a second topic on the same subject ?
So what you mean is "if light is HIGH you don't care what ir is because you're going to do the same thing".
So replace the last 2 if blocks with a simple
if (light==HIGH)
  delay(2000);
Steve
