I'm a beginner with 15 day of experience.
I'll post my code in the attachment. What I wanna get my ARD-UNO R3 to do is read the data (distance detected by ULTRASONIC SENSOR) and print it in the Serial Monitor. SO, I'm using this HC-SRO4 or something (That is what is printed on it - HC SR04). And , I did some long research and got pretty much every resource I need for this experiment.
But, with my luck, things had to get complicated.
-------------------------------------------ERROR MESSAGES------------------------------------------------------________________________________________________________________________________________Arduino: 1.6.8 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\yoyoy_000\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\yoyoy_000\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\yoyoy_000\Documents\Arduino\libraries\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10608 -build-path "C:\Users\YOYOY_~1\AppData\Local\Temp\build05775ebcdd946fbc6d963c4f7b8a0679.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\yoyoy_000\Documents\Arduino\libraries\NewPing\examples\NewPingExample\NewPingExample.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\yoyoy_000\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\yoyoy_000\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\yoyoy_000\Documents\Arduino\libraries\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10608 -build-path "C:\Users\YOYOY_~1\AppData\Local\Temp\build05775ebcdd946fbc6d963c4f7b8a0679.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\yoyoy_000\Documents\Arduino\libraries\NewPing\examples\NewPingExample\NewPingExample.ino"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\yoyoy_000\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.11\cores\arduino" "-IC:\Users\yoyoy_000\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.11\variants\standard" "C:\Users\YOYOY_~1\AppData\Local\Temp\build05775ebcdd946fbc6d963c4f7b8a0679.tmp\sketch\NewPingExample.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\yoyoy_000\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.11\cores\arduino" "-IC:\Users\yoyoy_000\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.11\variants\standard" "C:\Users\YOYOY_~1\AppData\Local\Temp\build05775ebcdd946fbc6d963c4f7b8a0679.tmp\sketch\NewPingExample.ino.cpp" -o "C:\Users\YOYOY_~1\AppData\Local\Temp\build05775ebcdd946fbc6d963c4f7b8a0679.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\yoyoy_000\Documents\Arduino\libraries\NewPing\examples\NewPingExample\NewPingExample.ino:4:20: fatal error: NewPing: No such file or directory
#include
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
END OF ERROR_______________
---------------------------------Any help I can get?-------------------------------------------------------------
MATERIALS:
ARDUINO UNO R3 (OFFICIAL BLUE THINGY)
BREADBOARD (IN A STANDARD KIT)
JUMPER WIRES (YEAH, ALL ARE SAME)
ULTRASONIC SENSOR
(MODULE HC-SR04)
SERIAL PORT
MY PC (SONY VAIO.Don't know how that matters, but just in case. Its Windows 10 with Arduino IDE 1.6.8 and the NewPing v1.5 and NewPing v1.7. All libraries fine. )
NewPingExample.ino (1.05 KB)
