I'm using Arduino mega 2560 and PN532 NFC contactless shield, wiring by UART interface. Can get UID values and Mifare from examples of PN532 library GitHub - elechouse/PN532: NFC library for Arduino using PN532 .
What I need to get is Answer to Reset (ATR) or Answer to Select (ATS) from card. Is there any way to get it ?
Probably I'm still finding a way to get ATS answer from card. I used examples codes and some codes I found it on internet. I don't know the codes to get ATS and I can't find function in codes to get ATS in the PN532 library. My wiring is
SDA -> 19
SCL -> 18
5v -> 5v
GND -> GND
I need codes from PN532 library or other way with C++ codes to get ATS
SDA -> 19
SCL -> 18
5v -> 5v
GND -> GND
card has no damage
I mean I need to know the codes to get ATS answer. Only I get is UID values which is the provided examples from PN532 library and select_apdu command from nfc.inDataExchange() function from PN532 library. still can't find ways to get ATS or ATR
The RX/TX signals of the PN532 aren't on the same pins as the I2C signals. So if you connected the SDA/SCL pins to the serial pins on the Arduino you have the reason why it doesn't work.
now I change to SPI mode and It works with it's examples and I got select apdu, ATQA, SAK and read mifare. what I need to get is ATS or ATR answer. I still find a proper way to get ATR or ATS answer.
