Can't get bitmaps displayed on GC9A01A (round display)
Hello everyone,
its my fist time working with displays and I tried a lot of different things but I just cant get simple bitmaps to be displayed on my GC9A01A display...
I am working with the following libraries:
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_GC9A01A.h"
#include <avr/pgmspace.h>
The code is from the Adafruit_GC9A01A.h example and I now want to get Bitmaps to be displayed. Everything else is working (text, lines, rectangles can be displayed!)
Also I used this tutorial a bit: Adafruit_GFX Img2Code ./gradlew
#include "SPI.h"
#define TFT_DC  7
#define TFT_CS 10
#define TFT_BL 6
#define TFT_MOSI 11
#define TFT_SCLK 13
#define TFT_MISO -1
#define TFT_RST 8
extern uint8_t epd_bitmap_Untitled_3[];
extern uint8_t title[];
Adafruit_GC9A01A tft(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST, TFT_MISO);
  Serial.println("GC9A01A Test!");
  tft.begin();
#if defined(TFT_BL)
  pinMode(TFT_BL, OUTPUT);
  digitalWrite(TFT_BL, HIGH); // Backlight on
#endif // end TFT_BL
  testText();
void loop(void) {
unsigned long testText() {
  tft.fillScreen(GC9A01A_BLACK);
  unsigned long start = micros();
  tft.drawBitmap(60, 60, epd_bitmap_Untitled_3, 120 , 120, GC9A01A_WHITE);
  return micros() - start;
With this code I get the following result:
But it should look like this:
Screenshot 2024-05-08 013554
I converted the bitmap with this website: image2cpp
And if I put the plain bytes-array back into the top right text field, I can see the array is working correctly so it has something to do with my code... So I tried the following:
When I use the tft.drawXBitmap instead of tft.drawBitmap (what is the difference??), I almost get a perfect picture on the screen (not really perfect but you can start to see the shapes):
What am I doing wrong?? Can someone help me?
I cant upload the bitmap itself but maybe this code helps you:
Dimensions are 120x120px .
const unsigned char epd_bitmap_Untitled_3 [] PROGMEM = {
// 'Untitled-3', 120x120px
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x7f, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00,
0x00, 0x00, 0x3f, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00,
0x00, 0x3f, 0xc0, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xf3, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0xfe, 0x00,
0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0xfc, 0x00, 0x00, 0x0f, 0x00, 0x1f, 0xff, 0xc0, 0x00,
0x00, 0x00, 0x00, 0x03, 0x00, 0x07, 0xff, 0x00, 0x00, 0x7f, 0x00, 0x06, 0x03, 0xc0, 0x00, 0x00,
0x00, 0x00, 0x03, 0x00, 0x3f, 0x87, 0x80, 0x00, 0xf8, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x03, 0x00, 0x7c, 0x01, 0xc0, 0x07, 0xc0, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x03, 0x00, 0xe0, 0x01, 0xc0, 0x07, 0x80, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
0x00, 0xc0, 0x01, 0xc0, 0x0e, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x01,
0xc0, 0x01, 0x80, 0x0c, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x01, 0x80,
0x01, 0x80, 0x0c, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x01, 0x80, 0x01,
0x80, 0x0c, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x01, 0x80, 0x03, 0x80,
0x0e, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x01, 0x80, 0x0f, 0x00, 0x07,
0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x01, 0xff, 0xfe, 0x00, 0x03, 0x00,
0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x01, 0xff, 0xf8, 0x00, 0x03, 0x80, 0x00,
0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x01, 0x80, 0x00, 0x00, 0x01, 0xc0, 0x00, 0x60,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x01, 0x80, 0x00, 0x00, 0x00, 0xe0, 0x00, 0x60, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x01, 0xc0, 0x00, 0x00, 0x00, 0x78, 0x00, 0x60, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x3e, 0x00, 0xe0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x06, 0x00, 0xe0, 0x00, 0x00, 0x00, 0x0f, 0x80, 0xc0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x06, 0x00, 0x70, 0x00, 0x00, 0x00, 0x03, 0xc0, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x06, 0x00, 0x3c, 0x00, 0x70, 0x00, 0x00, 0xe0, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x06, 0x00, 0x1f, 0xff, 0xf0, 0x00, 0x00, 0x60, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06,
0x00, 0x07, 0xff, 0xc0, 0x0c, 0x00, 0x60, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0f, 0x00, 0xe0, 0x60, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x0f, 0xff, 0xe0, 0x60, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x01, 0xff, 0x80, 0x70, 0x00, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x38, 0x01, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3f, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x01, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x1c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xf0, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x78, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x1c, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x0d, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x0f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07,
0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x00, 0x1f, 0xc0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x00, 0x3c, 0xe0, 0x00,
0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xf0, 0x00, 0x70, 0x78, 0x00, 0xff,
0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xb8, 0x00, 0x60, 0x38, 0x01, 0xe0, 0x3f,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x98, 0x00, 0xe0, 0x18, 0x07, 0x80, 0x07, 0x80,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x18, 0x00, 0xc0, 0x00, 0x0f, 0x00, 0x03, 0xc0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x1c, 0x00, 0x00, 0x00, 0x3c, 0x00, 0x01, 0xe0, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0c, 0x0c, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0xe0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x1c, 0x0e, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x38, 0x06, 0x00, 0x00, 0x00, 0xe0, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x70, 0x07, 0x00, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x60, 0x03, 0x80, 0x00, 0x01, 0x80, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0,
0x01, 0x80, 0x00, 0x01, 0x80, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x01,
0xc0, 0x00, 0x03, 0x80, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x00, 0xc0,
0x00, 0x03, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0xe0, 0x00,
0x03, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x60, 0x00, 0x03,
0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x60, 0x00, 0x03, 0x00,
0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x70, 0x00, 0x03, 0x80, 0x00,
0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x30, 0x00, 0x01, 0x80, 0x00, 0x00,
0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x38, 0x00, 0x01, 0x80, 0x00, 0x00, 0x38,
0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x18, 0x00, 0x01, 0x80, 0x00, 0x00, 0x30, 0x00,
0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x1c, 0x00, 0x01, 0x80, 0x00, 0x00, 0x30, 0x00, 0x00,
0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x0c, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00,
0x00, 0x00, 0x70, 0x00, 0x00, 0x0e, 0x00, 0x00, 0xe0, 0x00, 0x00, 0xe0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x60, 0x00, 0x00, 0x06, 0x00, 0x00, 0x60, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x7f, 0xff, 0xf0, 0x06, 0x00, 0x00, 0x70, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f,
0xff, 0xff, 0xff, 0x00, 0x00, 0x38, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x1f, 0xff, 0x00, 0x00, 0x1e, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0f, 0x81, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x03, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
I hope this is everything you need to understand my problem.
Thanks for helping!!
