Can't get client.get() to work
Hello! This is my simple code that reports using http get when a digital goes up and down:
#include <ArduinoHttpClient.h>
#include <WiFiNINA.h>
#include <SPI.h>
// constants won't change. They're used here to set pin numbers:
const int buttonPin = 0;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
char ssid[] = "The Guest";        // your network SSID (name)
char pass[] = "1717!201";    // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS;     // the Wifi radio's status
// variables will change:
int buttonState = HIGH;
int lastState = HIGH;// variable for reading the pushbutton status
WiFiClient c;
HttpClient client = HttpClient(c,"http://visualid.input-data.com");
  Serial.println("Iniciando AgroSens Bebederos");
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Fallo la comunicacion con el modulo WiFi");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < "1.0.0") {
    Serial.println("Actualiza el Firmware");
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
    Serial.print("Intentando conectarse a la red: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network:
    status = WiFi.begin(ssid, pass);
    Serial.println(status);
    // wait 10 seconds for connection:
    delay(10000);
  // you're connected now, so print out the data:
  Serial.print("Estas conectado a WiFi");
  printCurrentNet();
  printWifiData();
  Serial.println("Agrosens Bebederos Iniciado");
  pinMode(buttonPin, INPUT);
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
  if (buttonState == HIGH && lastState == LOW) {
    Serial.println("Sensor activado");
    client.get("/bebedero/1/ON");
    int statusCode = client.responseStatusCode();
    String response = client.responseBody();
    Serial.print("Status code: ");
    Serial.println(statusCode);
    Serial.print("Response: ");
    Serial.println(response);
      while (client.available()) {
        char c = client.read();
      Serial.print(c);
      delay(5000);
    SerialUSB.flush();
  if (buttonState == LOW && lastState == HIGH) {
    Serial.println("Sensor desactivado");
    client.get("/bebedero/1/OFF");
    Serial.println("Wait five seconds");
    delay(5000);
      Serial.print(c);
      delay(5000);
  lastState = buttonState;
void printWifiData() {
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  Serial.println(ip);
  // print your MAC address:
  byte mac[6];
  WiFi.macAddress(mac);
  Serial.print("MAC address: ");
  printMacAddress(mac);
void printCurrentNet() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print the MAC address of the router you're attached to:
  byte bssid[6];
  WiFi.BSSID(bssid);
  Serial.print("BSSID: ");
  printMacAddress(bssid);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.println(rssi);
  // print the encryption type:
  byte encryption = WiFi.encryptionType();
  Serial.print("Encryption Type:");
  Serial.println(encryption, HEX);
void printMacAddress(byte mac[]) {
  for (int i = 5; i >= 0; i--) {
    if (mac[i] < 16) {
      Serial.print("0");
    Serial.print(mac[i], HEX);
    if (i > 0) {
      Serial.print(":");
I get return code -2, which isn’t an HTTP return code, so I don’t know how to follow up on that.
Can somebody please help me?
Thanks in advance!
The awesome windsurf_ on IRC helped me out.
Turns out I had to remove the HTTP:// from the server address…
Leaving this in case somebody else has the same issue.
Thanks!
