I will look and see if the buzzer problem is in the code or circuit.
You could add a button to turn the MP theme off and on. If you want, I will look at that.
Wow, here is a coincidence. My son's name is Chance.
That's pretty cool about the shared name!
Today completely got away from me, so I won't be able to rebuild the circuit until tomorrow (I'm in EST, 5- the forum time).
I don't know if the lack of a buzzer when the wand and course leads touch was a construction or code error, so I'm going to revisit that when I get back to the project.
A music-on-off button would be cool. I'd like to see how that's done. One problem I have with the push-buttons in general is that they don't seat well on the solderless breadboard. I tried straightening the contacts, but that didn't help. Could that just be the ones supplied in the Starter Kit?
The one thing I was able to do today was read through your code. I found 4 instances of "buzz()" which included an argument for "11" (1 under "// free play", and 3 under "void showCountdown()"). I'm assuming I should change those 11's to 8's, right? But I also see "const int rs = 11, ..." at the top, in the 4th line of the code. I'm not sure if that reference to 11 is about the pin and/or whether it should be 8.
You are right about those switches. They can be a pain. I take a pair of needle nose and twist the legs 90 degrees so they fit into the breadboard easier. A marginal improvement.
You are also right about the pin 11. I missed changing that. Change those pins to 8. That is another thing about that code. Definitely written by an inexperienced coder. You should not use pin numbers like that in code. Give the pin a name, in global scope, then use the name in the code. That way, to change the pin number it needs done in only one place.
Leave the int rs =11; that is for the LCD. Just change the ones related to the buzzer.
I'm back...
I've got the board set up for Buzz Wire, with the LCD display including the change of buzzer 2 to pin 8. I've compiled and uploaded your code (with the corrections to buzzer 2). I've been over the connections with a flashlight and magnifying glass and they seem to be correct. But all I'm getting is the Monty Python theme.
When I touch the course and wand leads (wand to power; course grounded through two 220 resistors), there's no buzz. (Monty Python only plays through buzzer 1, incidentally. I'm guessing Coburn wrote it to play the music through buzzer 1 and the touch buzzer through buzzer 2.)
There's no display on the LCD (should be "BUZZ READY", right?). And when I press the button nothing happens except that the music slows down slightly. (BTW, good tip about twisting the button contacts inward.)
I also uploaded your LCD, "Hello World" code, which worked fine when I set up just for that, but I'm getting nothing on the LCD in this configuration.
In case you still think there's any hope, I've uploaded an annotated pdf of the LCD setup. But I'll understand if it looks hopeless ... it kind of feels that way.
Maybe I should just take Chance to Chuck E Cheese!
LCD set up.pdf (434 KB)
I don't see anything wrong with the wiring. Can you post the code that you are running? Does the display show anything?
groundFungus:
Nothing on the display, not even the back lighting.
I've attached the code as a Word doc. I copied it directly from Arduino, then added line numbers in Word in case that might help.
Buzzer Game code.pdf (96.9 KB)
It is OK for now, but in the future, please post in code tags. That way I can copy to the IDE (the IDE will insert line numbers). I have to remove the line numbers to be able put the code in the IDE.
How are the breadboard's bottom power rails getting power and ground. They are not tied to the top rails unless you make the connection.
And a hint to make things easier. Use red jumpers for 5V and black for ground. I use the colors of the jumpers to make things easier to trace. I go by the resistor color code and the jumpers color reflects the Uno pin number that the jumper comes from.
Whoops!! Sorry about that. I wasn't thinking. In case you haven't already gone to all that trouble, here it is, below.
Regarding power and ground, in the picture you can sort of see a red and a black lead going to the power and ground rails in the upper right corner of the board (from 5v and GND). It's pretty much in the middle of the picture. Then at the other end of those rails I have two orange leads, one taking the power and the other taking the ground to the opposite rails of the board.
#include <hd44780.h>
#include <hd44780ioClass/hd44780_pinIO.h> // Arduino pin i/o class header
#include "pitches.h" // include pitches
const int rs = 11, en = 12, db4 = 4, db5 = 5, db6 = 6, db7 = 7; // for all other devices
hd44780_pinIO lcd(rs, en, db4, db5, db6, db7);
// LCD geometry
const int LCD_COLS = 16;
const int LCD_ROWS = 2;
// music: Monty Python theme
int songState = 0;
int melody[] =
NOTE_F4, NOTE_E4, NOTE_D4, NOTE_CS4,
NOTE_C4, NOTE_B3, NOTE_AS3, NOTE_A3,
NOTE_G3, NOTE_A3, NOTE_AS3, NOTE_A3,
NOTE_G3, NOTE_C4, 0,
NOTE_C4, NOTE_A3, NOTE_A3, NOTE_A3,
NOTE_GS3, NOTE_A3, NOTE_F4, NOTE_C4,
NOTE_C4, NOTE_A3, NOTE_AS3, NOTE_AS3,
NOTE_AS3, NOTE_C4, NOTE_D4, 0,
NOTE_AS3, NOTE_G3, NOTE_G3, NOTE_G3,
NOTE_FS3, NOTE_G3, NOTE_E4, NOTE_D4,
NOTE_D4, NOTE_AS3, NOTE_A3, NOTE_A3,
NOTE_A3, NOTE_AS3, NOTE_C4, 0,
NOTE_GS3, NOTE_A3, NOTE_A4, NOTE_F4,
NOTE_F4, NOTE_C4, NOTE_B3, NOTE_G4,
NOTE_G4, NOTE_G4, NOTE_G4, 0,
NOTE_G4, NOTE_E4, NOTE_G4, NOTE_G4,
NOTE_FS4, NOTE_G4, NOTE_D4, NOTE_G4,
NOTE_G4, NOTE_FS4, NOTE_G4, NOTE_C4,
NOTE_B3, NOTE_C4, NOTE_B3, NOTE_C4, 0
int tempo[] =
8, 16, 8, 16,
8, 16, 8, 16,
16, 16, 16, 8,
16, 8, 3,
12, 16, 16, 16,
8, 16, 8, 16,
8, 16, 8, 16,
8, 16, 4, 12,
12, 16, 16, 16,
8, 16, 8, 16,
8, 16, 8, 16,
8, 16, 4, 12,
12, 16, 16, 16,
8, 16, 8, 16,
8, 16, 8, 16,
8, 16, 4, 16,
12, 17, 17, 17,
8, 12, 17, 17,
17, 8, 16, 8,
16, 8, 16, 8, 1
// non blocking setup
// free play
unsigned long previousMillis1 = 0; // time words last changed
const long interval1 = 1500; // interval between changing
// music
unsigned long previousMillis2 = 0; // time last changed
const long interval2 = 100; // interval between notes
int displayStatus = 0; // keep track of what's displayed
int mode = 0; // keep track of game mode -- change to 0 or 1 for different modes
bool countdown = false;
unsigned long previousMillis3 = 0; // time last changed
const long interval3 = 1000; // interval between countdown
int count = 20; // challenge mode timer
pinMode(9, INPUT); // setup circuit
pinMode(10, OUTPUT); // setup buzzer 1
pinMode(8, OUTPUT); // setup buzzer 2 // had to change this pin. conflict with LCD
pinMode(2, INPUT); // setup button
lcd.begin(LCD_COLS, LCD_ROWS);
lcd.print("BUZZ READY");
lcd.clear();
if (mode == 0)
// challenge mode
if (digitalRead(2) == HIGH)
delay(25);
countdown = true; // stop the countdown [shouldn’t this be ‘start the countdown’?]
countdown = false; // stop the countdown
if (countdown)
showCountdown(); // advance countdown
// free play
toggleFreePlay();
if (digitalRead(10) == HIGH)
delay(25);
while (digitalRead(10) == HIGH)
buzz(8, NOTE_B0, 1000 / 24); //[This was changed from 11 to 8]
sing();
// countdown the time remaining
unsigned long currentMillis = millis(); // current time
if (currentMillis - previousMillis3 >= interval3)
previousMillis3 = currentMillis;
--count;
showNumber(count);
if (count == 0)
// game over
countdown = false;
count = 20;
// reset countdown
// buzz 3 times
buzz(8, NOTE_B0, 1000 / 24); //[changed from 11 to 8]
delay(100);
delay(100);
void showNumber(int number)
lcd.clear();
lcd.setCursor(4,0);
lcd.print("-- ");
lcd.setCursor(7,0);
lcd.print(number);
lcd.print(" --");
void toggleFreePlay()
// scroll between words without blocking
if (currentMillis - previousMillis1 >= interval1)
previousMillis1 = currentMillis;
if (displayStatus == 1)
showPlay();
showFree();
void showPlay()
// write "PLAY" to the display
lcd.clear();
lcd.setCursor(6,0);
lcd.print("PLAY");
displayStatus = 2;
void showFree()
// write "Free" to the display
lcd.clear();
lcd.setCursor(6,1);
lcd.print("FREE");
displayStatus = 1;
void buzz(int targetPin, long frequency, long length)
/* Buzzer example function by Rob Faludi
http://www.faludi.com
https://gist.github.com/AnthonyDiGirolamo/1405180
long delayValue = 1000000 / frequency / 2; // calculate the delay value between transitions
//// 1 second's worth of microseconds, divided by the frequency, then split in half since
//// there are two phases to each cycle
long numCycles = frequency * length / 1000; // calculate the number of cycles for proper timing
//// multiply frequency, which is really cycles per second, by the number of seconds to
//// get the total number of cycles to produce
for (long i = 0; i < numCycles; i++) // for the calculated length of time...
digitalWrite(targetPin, HIGH); // write the buzzer pin high to push out the diaphragm
delayMicroseconds(delayValue); // wait for the calculated delay value
digitalWrite(targetPin, LOW); // write the buzzer pin low to pull back the diaphragm
delayMicroseconds(delayValue); // wait again for the calculated delay value
void sing()
// play the song in a non blocking way
if (currentMillis - previousMillis2 >= interval2)
previousMillis2 = currentMillis;
int noteDuration = 1000 / tempo[songState];
buzz(10, melody[songState], noteDuration);
int pauseBetweenNotes = noteDuration;
delay(pauseBetweenNotes);
// stop the tone playing:
buzz(10, 0, noteDuration);
++songState;
// start song again if finished
if (songState > 79)
songState = 14; // skip intro
But without changing anything and uploading my test code the LCD works?
If the bottom rails are getting power the backlight should light.
After I set it up for the full Buzz Wire game and nothing happened (except Monty Python), then I left it all as you see it and uploaded your LCD code. That didn't work either. It would seem that I must be doing something wrong, but I sure can't see it.
jjeffh:
groundFungus:
FYI, Charlie, I found my mistake. I set up just the LCD display on a different UNO and board, using your display code and it worked perfectly as I tested it with different placements of text. So I revisited the full Buzz Game set up and I found that I had connected LCD pin 16 to power instead of ground!
Now I see "Buzz Ready" and when I press the button I get the countdown from 20 seconds, resulting in a chirp from buzzer 2 when it reaches 0. When I manually change the variable "mode" to 1 in the code, then I get your flashing "Free" and "Play".
However, I'm still not getting a buzz when I touch the two leads together, so I'll investigate that set up.
I have not found another stupid mistake like the last one (yet), but there's something about the code I don't understand.
I see "pinMode(9, INPUT)" specified in the code, but I don't see any other reference to pin 9 in the code. Doesn't there have to be some place where the code says that if pin 9 is HIGH the buzzer should sound and the game should end? Or is that handled in a different way?
Pin 9 is connected to the "course" which is connected through two 220 resistors. The setup shows the lead to pin 9 goes to 1e on the board, with a 220 resistor in 1d. The resistor goes to 5d and another 220 resistor goes from 5e to 9e. The course is connected at 5a, and row 9 is grounded.
The the handle lead is connected directly to power. So if that circuit is completed, pin 9 should be HIGH and the buzzer should sound. I just can't see where in the code pin 9's input is read and the buzzer activated.
delay(25);
It looks to me like the 10 in that part of the code should be 9. Why would one read the buzzer1 output?
You got it! That worked.
So that's the whole project: music, display, two modes, and the wire-touch buzz. Now I just have to cut the pieces for the game board and lay out a suitable procedure that Chance and I can work on together to built this thing.
Thanks so much, Charlie! I've learned quite a bit from you in this thread. I've been looking at the Tutorials Point C++ training online. Perhaps as I go through their tutorials I can work on this code to test things out.
A few things I'd like to do are: 1) start and stop, or at least lower the volume of, the music; 2) stop the game and display "Game Over" when the wand touches the course; and 3) change between Free Play and Challenge Mode on the board instead of in the code.
For now, I'm just delighted to see it all working and to know this Christmas plan is actually going to work.
I doubt we're allowed to add more than one karma point at a time, but I'm going to see if I can give you a couple extra. You've been great.
Thank you. Glad you got it working. Hope that you and Chance have as enjoyment with this hobby as i have.
Merry Christmas to you and your's.
Charlie
groundFungus:
Thank you. Glad you got it working. Hope that you and Chance have as enjoyment with this hobby as i have.Merry Christmas to you and your's.
Charlie
Merry Christmas to you, too.
Hi did you end up getting the circuit to work? I'm trying to make the same one but can't seem to get the buzzer to buzz when the handle touches the circuit
Well this is a blast from the past! It feels like long time since I was doing that project. Which is to say, memory fades.
I seem to remember there was an error in Coburn's published code regarding the buzzers. (Actually, there were a few errors and omissions which groundFungus graciously corrected and created for me.) I had thought the wire buzz and the Monty Python theme both sounded on both buzzers, but I think it turned out we had to separate them. Check out posts 31, 32, and 33 above.
I'll post what think was the code I ended up with in two subsequent posts (the posting limit is 9,000 characters and with the comments, the code is 9,600).
In the end, there were 3 button options:
That last one is important! The Monty Python music is some real nice coding and gives the game a carnival feel, but it'll drive you crazy on that short loop.
In the final product, touching the wire with the wand beeps, stops the game, and displays, "Game Over! RESET to play again"
Good luck!!
Here's a link to pictures of the finished game: Buzz Game
And here's the first half of the code:
//PART 1 OF 2 PART POSTING
/*This version incorporates Charlie's solution
*for manually starting and stopping the music
*with the playMontyFlag.
*It also in the quit flag for ending the game
*as soon as the circuit on pin 9 is completed
*(i.e. when the handle touches the wire).
//Setting LCD pins 4, 6, 11, 12, 13, and 14
//Which correspond to UNO pins 4>11, 6>12, 11>4, 12>5, 13>6, 14>7
const int rs = 11, en = 12, db4 = 4, db5 = 5, db6 = 6, db7 = 7; // for all other devices (don't know what devices this refers to -jh)
//==== Charlie's code ====
//pins 3 and 13 are available
const int buttonPin = 13; // the pin that the pushbutton is attached to
const int ledPin = 3; // the pin that the (built-in) LED is attached to
// Variables will change:
bool buttonState = 0; // current state of the button
bool lastButtonState = 0; // previous state of the button
bool playMontyFlag = true; // initial value of play the tune flag
//^^^^ Charlie's code ^^^^
// LCD geometry
int songState = 0;
int melody[] =
int tempo[] =
8, 16, 8, 16,
8, 16, 8, 16,
16, 16, 16, 8,
16, 8, 3,
12, 16, 16, 16,
8, 16, 8, 16,
8, 16, 8, 16,
8, 16, 4, 12,
12, 16, 16, 16,
8, 16, 8, 16,
8, 16, 8, 16,
8, 16, 4, 12,
12, 16, 16, 16,
8, 16, 8, 16,
8, 16, 8, 16,
8, 16, 4, 16,
12, 17, 17, 17,
8, 12, 17, 17,
17, 8, 16, 8,
16, 8, 16, 8, 1
// non blocking setup (what is "non blocking"? -jh)
// free play
// music
int mode = 0; // keep track of game mode: change to 0 (challenge) or 1 (free play) for different modes
unsigned long previousMillis3 = 0; // time last changed (used in showCountdown)
const long interval3 = 1000; // interval between countdown (1 second)
int count = 21; // challenge mode timer
//Exit flag
bool quit = false;
// initialize the button pin as an input with internal pullup enabled
pinMode(buttonPin, INPUT_PULLUP);
// initialize the LED as an output:
pinMode(ledPin, OUTPUT);
// initialize serial communication:
// setup code runs once:
lcd.print(" BUZZ READY");
delay(5000);
lcd.clear();
lcd.setCursor(2,0);
lcd.print("Press button");
lcd.setCursor(1,1);
lcd.print("for timed play");
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState)
if (buttonState == LOW)
// if the current state is LOW then the button
// went from not pressed to pressed:
digitalWrite(ledPin, !digitalRead(ledPin));
// toggle a flag to run the sing function or not
playMontyFlag = !playMontyFlag;
if(playMontyFlag == true)
Serial.println("playing Monty Python tune");
Serial.println("Blessed Silence");
lastButtonState = buttonState;
//END OF PART 1 POSTING
(I can only post again after five minutes...)
I'm going to attempt to upload my Fritz diagram as a jpg. I seem to remember attachments are tricky on this forum, so I may not be able to. Unfortunately, this diagram doesn't include the button that turns off the music, but other than that I think it is up to date.
And here's part 2 of the code:
//START OF PART 2 OF 2 POSTINGS
/*============== START of TIMER BUTTON PRESS ===================*/
// Change mode manually here, in the code. 0 = challenge; 1 = free play
// NOTE: Challenge mode is Free Play until the button is pressed to start countdown
if (mode == 0)
// challenge mode
if (digitalRead(2) == HIGH) //Pin 2 is the button
delay(25); //Presumably there needs to be a 25ms delay to ensure the button was pressed
countdown = true; // start the countdown
if (countdown)
// free play
toggleFreePlay();
/*============== END of TIMER BUTTON PRESS ===================*/
//Pin 9 is the course-handle circuit. When 9 is activated "Game Over" is displayed and game ends.
//Press the white reset button on the UNO board to reload and play again.
if (digitalRead(9) == HIGH)
delay(25);
quit = true; //When the course circuit is complete the quit flag is set.
while (digitalRead(9) == HIGH)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Game Over! RESET");
lcd.setCursor(0,1);
lcd.print("to play again");
// Regarding exiting the loop, see Zoul007's post here: https://stackoverflow.com/questions/23096366/how-to-stop-a-loop-arduino
if (quit == true){exit(0);} //When the course circuit is broken again, the game ends
if (playMontyFlag == true)
sing();
} // END OF 'VOID LOOP'
--count;
showNumber(count);
if (count == 0)
// game over
quit = true; //TEST
countdown = false;
// reset countdown
count = 21;
// buzz 3 times
delay(100);
delay(100);
lcd.clear();
lcd.setCursor(0,0);
/*lcd.print("Handle down");
lcd.setCursor(0,1);
lcd.print("Game Over!");*/
lcd.setCursor(0,1);
if (quit == true){exit(0);} //TEST
lcd.clear();
lcd.setCursor(4,0);
lcd.print("-- ");
lcd.setCursor(7,0);
lcd.print(number);
lcd.print(" --");
showPlay();
showFree();
void showPlay()
lcd.clear();
lcd.setCursor(6,1);
lcd.print("PLAY");
displayStatus = 2;
void showFree()
lcd.clear();
lcd.setCursor(6,0);
lcd.print("FREE");
displayStatus = 1;
void sing()
++songState;
if (songState > 79)
//END OF PART 2 POSTING
