Can't get directory list after reading a file from SD.
I'm mostly getting all the SD functions to work except that I can't get a directory list after reading a file. For example if I follow this sequence the last directory list won't work.
get directory list... works
get contents of a file... works
get directory list... this one never works
Could someone please help me figure out what I am doing wrong? Here is my code,
#include <SD.h>
char inChar;
File MyFile;
File MyDir;
  Serial.println ("Starting...");
  if (!SD.begin(8)) Serial.println("Card failed, or not present");
  if (Serial.available()){
    inChar = (char)Serial.read();
    switch (inChar){
      case 'D':  // Directory
        MyDir = SD.open("/");
        if (MyDir){
          SdDirPrint(MyDir, 0);
          MyDir.close();
          Serial.println ("Finished listing directory");
        }else{
          Serial.println ("Couldn't open directory");
      case 'W':  //Write a file
        MyFile = SD.open("datalog.txt", FILE_WRITE);
        if (MyFile) {
          for (int index = 1; index < 10; index++){
            MyFile.print("Line ");
            MyFile.println (index);
          MyFile.close();
          Serial.println("Finished writing.");
          Serial.println("error opening file for write");
      case 'R':  //Read a file
        MyFile = SD.open("datalog.txt", FILE_READ);
        if (MyFile) {
          while (MyFile.available()) {
            Serial.write(MyFile.read());
          MyFile.close();
          Serial.println("Finished reading");
        }else{
          Serial.println ("Couldn't open file for read");
    Serial.println ("");
void SdDirPrint(File dir, int numTabs) {
   while(true) {
     File entry =  dir.openNextFile();
     if (! entry) {
       dir.rewindDirectory();
     for (uint8_t i=0; i<numTabs; i++) {
       Serial.print('\t');
     Serial.print(entry.name());
     if (entry.isDirectory()) {
       Serial.println("/");
       SdDirPrint(entry, numTabs+1);
       // files have sizes, directories do not
       Serial.print("\t\t");
       Serial.println(entry.size(), DEC);
     entry.close();
Looks like a workaround is to call .rewindDirectory() after a previous file read. Not sure why this is necessary after a previous file read but not after a previous directory read.
