Hello!
This is my first time posting here, so sorry for any mess-ups in advance.
So, I have an ESP8266 HUZZAH microcontroller wired up to a TSL2591 Lux Sensor and a single NeoPixel. I have confirmed that both the pixel and the sensor work on their own, using example codes I found. Now, I am attempting to combine the two codes with an if-else statement to have the NeoPixel shine one color is an arbitrary amount of lux is read, say 300, and then turn another color if the lux value is higher than 300. My current code runs, but it defaults to the else value, regardless of what the Lux Sensor reads, and I'm not sure why. The code is going to be in the first comment on here, since it is apparently too long to fit with this paragraph. Also, I know it's pretty messy with comments from the originals, but I plan on cleaning it up once it for sure works. Thank you in advance! - Collin
The code I am currently using
/* TSL2591 Digital Light Sensor */
/* Dynamic Range: 600M:1 */
/* Maximum Lux: 88K */
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_TSL2591.h"
#define PIN 12
#define NUMPIXELS 1
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 500; // delay for half a second
// Example for demonstrating the TSL2591 library - public domain!
// connect SCL to GPIO#5
// connect SDA to GPIO#4
// connect Vin to 3.3-5V DC
// connect GROUND to common ground
Adafruit_TSL2591 tsl = Adafruit_TSL2591(2591); // pass in a number for the sensor identifier (for your use later)
Displays some basic information on this sensor from the unified
sensor API sensor_t type (see Adafruit_Sensor for more information)
void displaySensorDetails(void)
sensor_t sensor;
tsl.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" lux");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" lux");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" lux");
Serial.println("");
Configures the gain and integration time for the TSL2591
void configureSensor(void)
// You can change the gain on the fly, to adapt to brighter/dimmer light situations
//tsl.setGain(TSL2591_GAIN_LOW); // 1x gain (bright light)
tsl.setGain(TSL2591_GAIN_MED); // 25x gain
// tsl.setGain(TSL2591_GAIN_HIGH); // 428x gain
// Changing the integration time gives you a longer time over which to sense light
// longer timelines are slower, but are good in very low light situtations!
tsl.setTiming(TSL2591_INTEGRATIONTIME_100MS); // shortest integration time (bright light)
// tsl.setTiming(TSL2591_INTEGRATIONTIME_200MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_300MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_400MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_500MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_600MS); // longest integration time (dim light)
/* Display the gain and integration time for reference sake */
Serial.print ("Gain: ");
tsl2591Gain_t gain = tsl.getGain();
switch (gain)
case TSL2591_GAIN_LOW:
Serial.println("1x (Low)");
case TSL2591_GAIN_MED:
Serial.println("25x (Medium)");
case TSL2591_GAIN_HIGH:
Serial.println("428x (High)");
case TSL2591_GAIN_MAX:
Serial.println("9876x (Max)");
Serial.print ("Timing: ");
Serial.print((tsl.getTiming() + 1) * 100, DEC);
Serial.println(" ms");
Serial.println("");
Program entry point for the Arduino sketch
void setup(void)
pixels.begin();
Serial.println("Starting Adafruit TSL2591 Test!");
if (tsl.begin())
Serial.println("Found a TSL2591 sensor");
Serial.println("No sensor found ... check your wiring?");
while (1);
/* Display some basic information on this sensor */
displaySensorDetails();
/* Configure the sensor */
configureSensor();
// Now we're ready to get readings ... move on to loop()!
Shows how to perform a basic read on visible, full spectrum or
infrared light (returns raw 16-bit ADC values)
void simpleRead(void)
// Simple data read example. Just read the infrared, fullspecrtrum diode
// or 'visible' (difference between the two) channels.
// This can take 100-600 milliseconds! Uncomment whichever of the following you want to read
uint16_t x = tsl.getLuminosity(TSL2591_VISIBLE);
//uint16_t x = tsl.getLuminosity(TSL2591_FULLSPECTRUM);
//uint16_t x = tsl.getLuminosity(TSL2591_INFRARED);
Serial.print("[ "); Serial.print(millis()); Serial.print(" ms ] ");
Serial.print("Luminosity: ");
Serial.println(x, DEC);
Show how to read IR and Full Spectrum at once and convert to lux
void advancedRead(void)
// More advanced data read example. Read 32 bits with top 16 bits IR, bottom 16 bits full spectrum
// That way you can do whatever math and comparisons you want!
uint32_t lum = tsl.getFullLuminosity();
uint16_t ir, full;
ir = lum >> 16;
full = lum & 0xFFFF;
Serial.print("IR: "); Serial.print(ir); Serial.print(" ");
Serial.print("Full: "); Serial.print(full); Serial.print(" ");
Serial.print("Visible: "); Serial.print(full - ir); Serial.print(" ");
Serial.print("Lux: "); Serial.println(tsl.calculateLux(full, ir));
Performs a read using the Adafruit Unified Sensor API.
void unifiedSensorAPIRead(void)
/* Get a new sensor event */
sensors_event_t event;
tsl.getEvent(&event);
/* Display the results (light is measured in lux) */
Serial.print("[ "); Serial.print(event.timestamp); Serial.print(" ms ] ");
if ((event.light == 0) |
(event.light > 4294966000.0) |
(event.light < -4294966000.0))
/* If event.light = 0 lux the sensor is probably saturated */
/* and no reliable data could be generated! */
/* if event.light is +/- 4294967040 there was a float over/underflow */
Serial.println("Invalid data (adjust gain or timing)");
Serial.print(event.light); Serial.println(" lux");
Arduino loop function, called once 'setup' is complete (your own code
should go here)
void loop(void)
//simpleRead();
; advancedRead();
// unifiedSensorAPIRead();
int sensorPin = 4;
int sensorValue = 0;
sensorValue = analogRead(sensorPin); // read the value from the sensor
if (sensorValue < 300)
// action A
for (int i = 0; i < NUMPIXELS; i++) {
// pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
pixels.setPixelColor(i, pixels.Color(100, 100, 100));
pixels.show(); // This sends the updated pixel color to the hardware.
delay(delayval); // Delay for a period of time (in milliseconds).
// action B
pixels.setPixelColor(i, pixels.Color(1, 1, 1));
That sensor communicates with the microcontroller using I2C. Why do you think that merely taking an "analogRead" of pin 4 will give you any meaningful information?
See that's my problem, apparently. I'm very new to programming, especially concerning the hardware I'm using, and I wasn't sure what other code to use besides the analog read.
