Can't get gyro/lcd code to work together
I'm new to this so there are some poor methods in my code when I try to introduce the LCD into the loop. My issue is that the LCD delay and the servo delay are interfering with each other. How can I isolate them? I like the 50ms response for the servo. But I would like maybe a 200ms refresh for the LCD. But in their current state they are giving a very odd response if I have them both in the loop. The servo is spinning slower as though it's adding both delays. If I disable the LCD it all goes back to normal. Any ideas? Could someone please show me the correct method so I can expand in the future? Thanks!!!!
I've got this so far:
#include<Wire.h>
const int MPU_addr=0x68;  // I2C address of the MPU-6050
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
//SERVO
#include <Servo.h>
Servo microservo1;
int servo_pin = 8;
//MAPPED VALUES
int16_t AcXmapped, AcYmapped, AcZmapped;
//LCD
#include <LiquidCrystal.h>
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
//initializes the library
void setup(){
  //SERVO SETUP
  microservo1.attach ( servo_pin );
  //WIRE SETUP
  Wire.begin();
  Wire.beginTransmission(MPU_addr);
  Wire.write(0x6B);  // PWR_MGMT_1 register
  Wire.write(0);     // set to zero (wakes up the MPU-6050)
  Wire.endTransmission(true);
  Serial.println("Transmission Line Initializing");
  delay(350);
  //print("3"); print("2"); print("1");
  Serial.println("3");
  Serial.println("2");
  Serial.println("1");
  //LCD SETUP
  lcd.begin(16,2); //setup LCD number of columns and rows
  digitalWrite(9,1); //can either go 0 --> 1 or LOW --> HIGH || turns LCD on or off ||
  analogWrite(6,70); //contrast setting for the text on the LCD
void loop(){
  //WIRE LOOP
  Wire.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
  Wire.endTransmission(false);
  Wire.requestFrom(MPU_addr,14,true);  // request a total of 14 registers
  AcX=Wire.read()<<8|Wire.read();  // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
  AcY=Wire.read()<<8|Wire.read();  // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
  AcZ=Wire.read()<<8|Wire.read();  // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
  Tmp=Wire.read()<<8|Wire.read();  // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
  GyX=Wire.read()<<8|Wire.read();  // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
  GyY=Wire.read()<<8|Wire.read();  // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
  GyZ=Wire.read()<<8|Wire.read();  // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
  Serial.print(" | AcX = "); Serial.print(AcX);
  Serial.print(" | AcY = "); Serial.print(AcY);
  Serial.print(" | AcZ = "); Serial.print(AcZ);
  //Serial.print(" | Tmp =  "); Serial.print(Tmp/340.00+36.53);  //equation for temperature in degrees C from datasheet
  Serial.print(" | GyX = "); Serial.print(GyX);
  Serial.print(" | GyY = "); Serial.print(GyY);
  Serial.print(" | GyZ = "); Serial.println(GyZ);
  //MAPPING the values from e.g. AcX to AcXmapped so they're better values for servo control.
  //set the AcX inside the map to negative if you want to invert the rotation of the servo.
  AcXmapped = map (AcX, -17000, 17000, 0, 180); //ROLL
  AcYmapped = map (AcY, -17000, 17000, 0, 180); //PITCH
  AcZmapped = map (AcZ, -17000, 17000, 0, 180); //YAW
  //SERVO LOOP
  microservo1.write(AcYmapped);
  //50 ms response between movements
  delay(50);
  //LCD LOOP
  lcd.setCursor(0,0); //set the cursor to (0,0)
  lcd.print(AcYmapped);
  delay(50);
  //EXTRA LCD
  lcd.noAutoscroll(); //turns off autoscroll
  lcd.clear(); //clears the screen for the next loop
ardoyouknowwhoiam:
I am getting errors when compiling. Could someone please show me what's wrong
Kinda need to see the compiler errors first before we can tell you what's wrong. The compiler itself tells you (in the error) what's wrong.
Power_Broker:
Forgot to add those! Thanks, see below. Even if I do what it says I am presented with more and more errors. There's probably something simple that I'm doing wrong that somebody with more experience will pick up on straight away.
sketch_apr26a:89:3: error: 'lcd' does not name a type
sketch_apr26a:90:3: error: 'lcd' does not name a type
sketch_apr26a:93:1: error: expected declaration before '}' token
exit status 1
You had an extra curly brace. Not sure if this will fix everything, but try this:
#include<Wire.h>
//SERVO
#include <Servo.h>
Servo microservo1;
int servo_pin = 8;
//MAPPED VALUES
//LCD
void setup(){
  //SERVO SETUP
  //WIRE SETUP
  Wire.begin();
  delay(350);
  //LCD SETUP
void loop(){
  //WIRE LOOP
  //SERVO LOOP
  delay(50);
  //LCD LOOP
  delay(50);
  //EXTRA LCD
Power_Broker:
#include<Wire.h>
//SERVO
#include <Servo.h>
Servo microservo1;
int servo_pin = 8;
//MAPPED VALUES
//LCD
void setup(){
//SERVO SETUP
  //WIRE SETUP
  Wire.begin();
  delay(350);
//LCD SETUP
void loop(){
//WIRE LOOP
  //SERVO LOOP
  delay(50);
//LCD LOOP
  delay(50);
//EXTRA LCD
My other issue now is that the LCD delay and the servo delay are interfering with each other. How can I isolate them? I like the 50ms response for the servo. But I would like maybe a 200ms refresh for the LCD. But in their current state they are giving a very odd response if I have them both in the loop. If I disable the LCD it all goes back to normal. Any ideas?
Thank you for picking up on that curly brace!!!
This should help
The several things at a time tutorial expands on the method shown by the blink without delay example.
Power_Broker:
This should help
groundFungus:
thank you both I will give this a look and post back with results
