Can't get lifa base to arduino compiler
Hi I am using LIFA in my project. while compiling lifa base.ide in arduino,i am facing these errors. could anyone give solution to these errors
Arduino: 1.6.7 (Windows 8.1), Board: “Arduino/Genuino Uno”
C:\Program Files (x86)\National Instruments\LabVIEW 2010\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino: In function ‘void processCommand(unsigned char*)’:
C:\Program Files (x86)\National Instruments\LabVIEW 2010\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino:150:60: warning: left shift count >= width of type [enabled by default]
duration=(command[8]+ (command[7]<<8)+ (command[6]<<16)+(command[5]<<24));
C:\Program Files (x86)\National Instruments\LabVIEW 2010\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino:150:77: warning: left shift count >= width of type [enabled by default]
Sketch uses 19,678 bytes (61%) of program storage space. Maximum is 32,256 bytes.
Global variables use 1,135 bytes (55%) of dynamic memory, leaving 913 bytes for local variables. Maximum is 2,048 bytes.
avrdude: ser_open(): can’t open device “\.\COM7”: The system cannot find the file specified.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
“Show verbose output during compilation”
enabled in File > Preferences.
LIFA is no longer supported.
Try LINX.
