Cant get multiple SPI devices working at the same time (ST7735, MAX31865)
I'm having trouble to get a ST7735 tft and MAX31865 PT100 board working at the same time with my Uno R3. I can get both of them working by themselves with the examples available. I also can get the MAX81365 to post a correct temperature once, but as soon as I initialize the ST7735 it stops working and returns a reading which is just 0, or over/undervoltage error.
What am I doing wrong?
  This is a library for the Adafruit PT100/P1000 RTD Sensor w/MAX31865
  Designed specifically to work with the Adafruit RTD Sensor
  ----> https://www.adafruit.com/products/3328
  This sensor uses SPI to communicate, 4 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
//#include <SPI.h>
//#include <Arduino.h>
#include <Adafruit_MAX31865.h>
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#include <Adafruit_ST7789.h> // Hardware-specific library for
#define TFT_CS        10
#define TFT_RST        4 // Or set to -1 and connect to Arduino RESET pin
#define TFT_DC         7
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
// Use software SPI: CS, DI, DO, CLK
Adafruit_MAX31865 thermo = Adafruit_MAX31865(2, 11, 12, 13);
// use hardware SPI, just pass in the CS pin
//Adafruit_MAX31865 thermo = Adafruit_MAX31865(10);
// The value of the Rref resistor. Use 430.0 for PT100 and 4300.0 for PT1000
#define RREF      430.0
// The 'nominal' 0-degrees-C resistance of the sensor
// 100.0 for PT100, 1000.0 for PT1000
#define RNOMINAL  100.0
uint8_t count = 0;
  Serial.println("Adafruit MAX31865 PT100 Sensor Test!");
  pinMode (2, OUTPUT);
  pinMode (10, OUTPUT);
  //SPI.begin();
  uint16_t time = millis();
  time = millis() - time;
  thermo.begin(MAX31865_3WIRE);  // set to 2WIRE or 4WIRE as necessary
  //digitalWrite(10, HIGH);
  //digitalWrite(2, HIGH);
  count += 1;
  Serial.print(count);
  //SPI.beginTransaction(SPISettings(14000000, MSBFIRST, SPI_MODE0));
  digitalWrite(2, LOW);
  uint16_t rtd = thermo.readRTD();
  Serial.print("RTD value: "); Serial.println(rtd);
  float ratio = rtd;
  ratio /= 32768;
  Serial.print("Ratio = "); Serial.println(ratio,8);
  Serial.print("Resistance = "); Serial.println(RREF*ratio,8);
  Serial.print("Temperature = "); Serial.println(thermo.temperature(RNOMINAL, RREF));
  float temptest = thermo.temperature(RNOMINAL, RREF);
  // Check and print any faults
  uint8_t fault = thermo.readFault();
  if (fault) {
    Serial.print("Fault 0x"); Serial.println(fault, HEX);
    if (fault & MAX31865_FAULT_HIGHTHRESH) {
      Serial.println("RTD High Threshold");
    if (fault & MAX31865_FAULT_LOWTHRESH) {
      Serial.println("RTD Low Threshold");
    if (fault & MAX31865_FAULT_REFINLOW) {
      Serial.println("REFIN- > 0.85 x Bias");
    if (fault & MAX31865_FAULT_REFINHIGH) {
      Serial.println("REFIN- < 0.85 x Bias - FORCE- open");
    if (fault & MAX31865_FAULT_RTDINLOW) {
      Serial.println("RTDIN- < 0.85 x Bias - FORCE- open");
    if (fault & MAX31865_FAULT_OVUV) {
      Serial.println("Under/Over voltage");
    thermo.clearFault();
  //SPI.endTransaction();
  digitalWrite(10, LOW);
  tft.initR(INITR_BLACKTAB);
  tft.fillScreen(ST77XX_BLACK);
  testdrawtext(count,ST77XX_RED,3);
  //SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE1));
void testdrawtext(uint8_t count, uint16_t color, uint16_t size) {
  tft.setRotation(3); // rotate 90 degrees
  tft.setTextSize(size);
  tft.setCursor(0, 0);
  tft.setTextColor(color);
  tft.setTextWrap(true);
  tft.print(count);
You trying to use software SPI, try the hardware SPI option instead.
It worked! Thank you, such an easy problem. Now I only have one weird behaviour. Every loop the screen flickers white before turning black again, do you know what can cause it?
