I am using the UART @250kbps to process incoming frames of DMX values.
I use a frame counter to downsample (i.e. I only read every 4th frame).
And then I want to grab a few values from the DMX frame and then send them out some other pins via NewSoftSerial at a lower baud rate.
So far this is not working and I think it has to do with the conflict between NewSoftSerial and the code setup for processing the DMX (which uses Timer2).
Can anyone see what’s wrong? (this is all on a Duemilanove)
* DMX-512 Reception *
* Developed by Max Pierson *
* Version Rev13 9 July 2009 *
* Released under the WTFPL license, although I would *
* appreciate Attribution and Share-Alike *
* See blog.wingedvictorydesign.com for the latest version. *
//!!!!! TWI.h speed increased from 100kHz to 400kHz!
#include <avr/pgmspace.h>
#include <NewSoftSerial.h>
#define DMX_MAX_CHANNELS 3 //number of DMX values to read from the starting adress onwards.
#define FRAME_RATE 4 // used to reduce the frame rate of the incoming DMX which is too fast (250kbps) down to a fraction of this max speed
/******************************* Addressing variable declarations *****************************/
unsigned int dmxaddress = 0;
/* The dmx address we will be listening to. The value of this will be set in the Addressing()
* function, if triggered, and read from EEPROM addresses 510 and 511. */
// int dipswitch[9] = {8,17,16,15,14,7,6,5,4};
int dipswitch[9] = {4,5,6,7,14,15,16,17,8};
/******************************* MAX485 variable declarations *****************************/
#define RECEIVER_OUTPUT_ENABLE 2
/* receiver output enable (pin2) on the max485.
* will be left low to set the max485 to receive data. */
#define DRIVER_OUTPUT_ENABLE 3
/* driver output enable (pin3) on the max485.
* will left low to disable driver output. */
#define RX_PIN 0 // serial receive pin, which takes the incoming data from the MAX485.
#define TX_PIN 1 // serial transmission pin
/******************************* DMX variable declarations ********************************/
volatile byte i = 0; //dummy variable for dmxvalue[]
volatile byte dmxreceived = 0; //the latest received value
volatile unsigned int dmxcurrent = 0; //counter variable that is incremented every time we receive a value.
volatile byte dmxvalue[DMX_MAX_CHANNELS]; //stores the DMX values we're interested in using.
volatile boolean dmxnewvalue = 0; //set to 1 when new dmx values are received.
volatile byte frameCount = 0;
int counter = 0;
/******************************* Timer2 variable declarations *****************************/
volatile byte zerocounter = 0;
/* a counter to hold the number of zeros received in sequence on the serial receive pin.
* When we've received a minimum of 11 zeros in a row, we must be in a break. As written,
* the timer2 ISR actually checks for 22 zeros in a row, for the full 88uS break. */
#define SETBAUD 57600
#define xbeeRX 9 //digital pin 18
#define xbeeTX 10 //digital pin 19
NewSoftSerial xbee(xbeeRX,xbeeTX);
//Wire.begin();
xbee.begin(SETBAUD);
/******************************* Max485 configuration ***********************************/
pinMode(RECEIVER_OUTPUT_ENABLE, OUTPUT);
pinMode(DRIVER_OUTPUT_ENABLE, OUTPUT);
digitalWrite(RECEIVER_OUTPUT_ENABLE, LOW);
digitalWrite(DRIVER_OUTPUT_ENABLE, LOW); //sets pins 3 and 4 to low to enable reciever mode on the MAX485.
pinMode(RX_PIN, INPUT); //sets serial pin to receive data
/******************************* Addressing subroutine *********************************/
for (int i = 0; i<9; i++)
pinMode(dipswitch[i], INPUT);
digitalWrite(dipswitch[i], HIGH);
dmxaddress = getAddress();
//dmxaddress = dipAddress;
dmxaddress = dmxaddress + 3;
/* this will allow the USART receive interrupt to fire an additional 3 times for every dmx frame.
* Here's why:
* Once to account for the fact that DMX addresses run from 0-511, whereas channel numbers
* start numbering at 1.
* Once for the Mark After Break (MAB), which will be detected by the USART as a valid character
* (a zero, eight more zeros, followed by a one)
* Once for the START code that precedes the 512 DMX values (used for RDM). */
/******************************* USART configuration ************************************/
Serial.begin(250000);
/* Each bit is 4uS long, hence 250Kbps baud rate */
cli(); //disable interrupts while we're setting bits in registers
bitClear(UCSR0B, RXCIE0); //disable USART reception interrupt
/******************************* Timer2 configuration ***********************************/
//NOTE: this will disable PWM on pins 3 and 11.
bitClear(TCCR2A, COM2A1);
bitClear(TCCR2A, COM2A0); //disable compare match output A mode
bitClear(TCCR2A, COM2B1);
bitClear(TCCR2A, COM2B0); //disable compare match output B mode
bitSet(TCCR2A, WGM21);
bitClear(TCCR2A, WGM20); //set mode 2, CTC. TOP will be set by OCRA.
bitClear(TCCR2B, FOC2A);
bitClear(TCCR2B, FOC2B); //disable Force Output Compare A and B.
bitClear(TCCR2B, WGM22); //set mode 2, CTC. TOP will be set by OCRA.
bitClear(TCCR2B, CS22);
bitClear(TCCR2B, CS21);
bitSet(TCCR2B, CS20); // no prescaler means the clock will increment every 62.5ns (assuming 16Mhz clock speed).
OCR2A = 64;
/* Set output compare register to 64, so that the Output Compare Interrupt will fire
* every 4uS. */
bitClear(TIMSK2, OCIE2B); //Disable Timer/Counter2 Output Compare Match B Interrupt
bitSet(TIMSK2, OCIE2A); //Enable Timer/Counter2 Output Compare Match A Interrupt
bitClear(TIMSK2, TOIE2); //Disable Timer/Counter2 Overflow Interrupt Enable
sei(); //reenable interrupts now that timer2 has been configured.
} //end setup()
//byte x = 0;
// the processor gets parked here while the ISRs are doing their thing.
if (dmxnewvalue == 1) { //when a new set of values are received, jump to action loop...
if (frameCount == FRAME_RATE)
frameCount = 0;
action();
dmxnewvalue = 0;
dmxcurrent = 0;
zerocounter = 0; //and then when finished reset variables and enable timer2 interrupt
i = 0;
} //end loop()
//Timer2 compare match interrupt vector handler
ISR(TIMER2_COMPA_vect) {
if (bitRead(PIND, PIND0)) { // if a one is detected, we're not in a break, reset zerocounter.
zerocounter = 0;
else {
zerocounter++; // increment zerocounter if a zero is received.
if (zerocounter == 22) // if 22 0's are received in a row (88uS break)
bitClear(TIMSK2, OCIE2A); //disable this interrupt and enable reception interrupt now that we're in a break.
bitSet(UCSR0B, RXCIE0);
} //end Timer2 ISR
ISR(USART_RX_vect)
dmxreceived = UDR0;
/* The receive buffer (UDR0) must be read during the reception ISR, or the ISR will just
* execute again immediately upon exiting. */
dmxcurrent++; //increment address counter
if(dmxcurrent > dmxaddress)
{ //check if the current address is the one we want.
if (frameCount == 0) dmxvalue[i] = dmxreceived;
i++;
if(i == DMX_MAX_CHANNELS)
dmxnewvalue = 1; //set newvalue, so that the main code can be executed.
frameCount++;
} // end ISR
int getAddress()
int _address = 0;
_address = 2*_address + !digitalRead(dipswitch[i]);
return _address;
void action()
/*********** Put what you want the code to do with the values (dmxvalue) here *************
example code: print out the received values to the serial port, and set PWM pins 5 and 6
to the first two values received. You can take this code out and put your own in.*/
int val;
xbee.print("3 DMX bytes read!!!");
return; //go back to loop()
} //end action() loop
