cant get own sketch to compile
I get the following error when trying to compile:
o: In function __static_initialization_and_destruction_0': undefined reference to ServoTimer2::ServoTimer2()‘o: In function loop': o: In function setup’:
#include <ServoTimer2.h>
ServoTimer2 servosteer;  // create servo object to control a servo
ServoTimer2 servospeed;  // create servo object to control a servo
//MEGA pin 23 receive pin - displays characters sent by RF
#include <VirtualWire.h>
#undef int
#undef abs
#undef double
#undef float
#undef round
  servosteer.attach(3);  // attaches the servo on pin 25 to the servo object
  servospeed.attach(4);  // attaches the servo on pin 27 to the servo object
  // lcd.init();
  Serial.begin(9600);      // Debugging only
  Serial.println("setup");
  // Initialise the IO and ISR
  vw_set_ptt_inverted(true); // Required for DR3100
  vw_setup(4000);       // Bits per sec
  vw_set_rx_pin(8);
  vw_rx_start();       // Start the receiver PLL running
  uint8_t buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  if (vw_get_message(buf, &buflen)) // Non-blocking
    //invalid message length must be S/B/F/L/R + number (max 3 digits)
    if (buflen < 3 || buflen > 5)
      return;
    digitalWrite(13, true); // Flash a light to show transmitting
    char val[buflen]; //Same as buf, last char will be used for null terminator
    memset(val, '\0', sizeof(val));
    //Copy value from string i.e. 213 from R213 into separate string
    strncpy(val, (char *)buf + 1, buflen - 1);
    //convert string containing value to integer e.g. "213" to 213.
    int VAL = atoi ( val );
    switch (buf[0]) {
    case 'X': //Deadmans finger stop all
      Serial.print("Deadmans finger");
      servospeed.write(1500);
    case 'P':
      Serial.print("Pitch ");
      Serial.println(VAL);
      servospeed.write(544+VAL*10);
    case 'R':
      Serial.print("Roll ");
      servosteer.write(544+VAL*10);
    default:
  digitalWrite(13, false); // Flash a light to show transmitting
Any help greatly appreciated thanks in advance!
Can you get a minimal 'hello world' program to compile with servotimer2 ?
Why are you undefing data types? :o
