Can't get SoftwareSerial to work right on Nano V3
Hi!
I'm trying to use SoftwareSerial on arduino Nano V3. I have compiled and uploaded example from Arduino - Home with zero modifications, but it doesn't work right. I connected FTDI TTL converter to pins 10,11 and ground and writing and reading from same pc to both ports. It works fine if I send from hardware UART to software port, but in other direction when I try to send long string without delays it just passes through only 2-3 first characters. If I add delays (0.1 sec) between sending characters it works fine too, but I need to transfer data at least at 4800bps.
Are the grounds connected? Please post a photo of your setup.
Edit: Removed silly question.
You might want to change to AltSoftSerial, if the pins used there are still free in your project. AltSoftSerial Library, for an extra serial port
pylon:
Right now while trying eliminate possible problems I changed pins to 3,4 and USB-TTL converter to another one (not ftdi), here is photo of current setup:
Code:
#include <SoftwareSerial.h>
SoftwareSerial icom(3, 4);
  icom.begin(9600);
  if(Serial.available() > 0) {
    int b = Serial.read();
    icom.write(b);
  if(icom.available() > 0) {
    int c = icom.read();
    Serial.write(c);
Host code:
#!/usr/bin/python
import sys
import serial
import time
data = ''.join([chr(i) for i in range(0, 256)])
s = serial.Serial(sys.argv[1], 9600)
if len(sys.argv)>2:
    #s.write(data)
    for i in range(0,256):
        s.write(data[i])
        #time.sleep(0.1)
    s.flush()
    s.close()
    sys.exit(0)
d = s.read(256)
if d!=data:
    print repr(data)
    print repr(d)
else:
    print 'ok'
s.close()
pylon:
I'll try it.
bazu:
pylon:
I'll try it.
Funny thing, AltSoftSerial worked with FTDI converter, but not with cp2102...
I don't use CP21XX converters anymore, I had too much problems with them, so I'm not really surprised. Can you live with the AltSoftSerial solution?
