can't get the U-blox neo 6m to work
Hi, I have been struggling to get the u-blox neo 6m to work. I haven’t gotten further than uploading this sketch:
#include <SoftwareSerial.h>
// setup gps serial
int gpsTxPin = 8;
int gpsRxPin = 9;
SoftwareSerial gpsSerial(gpsTxPin, gpsRxPin);
  Serial.begin(9600);  //set monitor to 9600
  gpsSerial.begin(9600); //adjust for GPS unit
  Serial.println("Ready!");
  while(gpsSerial.available())
    char c = gpsSerial.read();
    Serial.print(c);
and getting this from this serial monitor:
Ready!
$GPRMC,,V,,,,,,,,,,N*53
$GPVTG,,,,,,,,,N*30
$GPGGA,,,,,,0,00,99.99,,,,,,*48
$GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99*30
$GPGSV,1,1,03,09,,,27,29,,,26,30,,,23*7B
$GPGLL,,,,,,V,N*64
$GPVTG,,,,,,,,,N*30
$GPGSV,1,1,03,09,,,25,29,,,23,30,,,22*7D
$GPGLL,,,,,,V,N*64
$GPVTG,,,,,,,,,N*30
$GPGSV,1,1,03,09,,,22,29,,,19,30,,,19*7B
$GPGLL,,,,,,V,N*64
$GPVTG,,,,,,,,,N*30
$GPGSV,1,1,03,09,,,19,29,,,11,30,,,16*74
$GPGLL,,,,,,V,N*64
$GPVTG,,,,,,,,,N*30
$GPGSV,1,1,03,09,,,14,29,,,09,31,,,20*74
I have tried some library and they don’t seem to work what is not that weird considering the fact that I didn’t receive any useful information form the module.
I have tried to module outdoors, 3.3v and 5v but that didn’t change anything.
Does someone knows how to fix this?
(I got the module form here: https://www.aliexpress.com/item/1Set-GPS-Module-GY-NEO6MV2-NEO-6M-With-Flight-Control-EEPROM-RS232-TTL-Large-Antenna-For/32803522576.html?spm=a2g0s.9042311.0.0.27424c4dZtJe3A )
The module is working fine, but does not have a satellite fix.
The module must have an antenna properly attached, and you must be outdoors, with a clear view of the sky.
You may have to wait over 15 minutes to get a "factory fresh", cold start satellite fix.
I have been trying to get connection outside for more then an hour and still nothing... So I can conclude the antenna is bad?
That, or the connection is bad. EDIT: did you install a battery, as required (mentioned on the product page)?
The antenna connector shown on the product page is rather flimsy and won't survive misalignment. You might try disconnecting, check for bent segments, and reconnecting it.
At the price of a good cup of cappuccino, consider buying more than one of those modules.
Sorry for the late response but I looks like I already have a battery also I changed the antenna and it still doesn't work. Any other suggestions? :confused:
