Hi, I'm trying to combine a sin wave generator and a VU meter. The problem is that the wave crested is distorted.
long sumOfSquares = 0;
for (int i=0; i<numberOfSamples; i++) { //take many readings and average them
sample = analogRead(1); //take a reading
signal1 = (sample - middleValue); //work out its offset from the center
signal2 = signal1 * signal1; //square it to make all values positive
sumOfSquares += signal2; //add to the total
averageReading = sumOfSquares/numberOfSamples; //calculate running average
runningAverage=(((averagedOver-1)*runningAverage)+averageReading)/averagedOver;
/* if (runningAverage>threshold){ //is average more than the threshold ?
digitalWrite(ledPin, HIGH); //if it is turn on the LED
}else{
digitalWrite(ledPin, LOW); //if it isn't turn the LED off
Serial.println(runningAverage); //print the value so you can check it
//delay (10);
if (runningAverage > 0)
digitalWrite(led[1], HIGH);
else { digitalWrite(led[1], LOW);}
Even when I disconnect all the LED's and the electret microphone I'm having this problem. There is something wrong with the code itself. Any help is greatly appreciated.
Phas_Freq_VU.ino (3.69 KB)
Waveforms.h (86.7 KB)
