can't get y motor to run separate number of revolutions
I have Adruino Uno with CNC Shield V 3.00 and Chipset 4988 with 2) Kuman 17HD48002H-22B .These motors are Bipolar 4 Wire (no common) stepper motors.
Motor in the X axis works perfectly. It does it’s 25000 steps CW and CCW direction.
The Y motor which goes in Clockwise direction work good except I would like to extend the number of rotations, separately from the X motor steps.
On the 3rd last line of the script, I have re-itereated the following line:
step (true, Y_DIR, Y_STP, steps); // y axis motor forward 1 laps, the 200 step is a circle.[/b]
This causes the Y motor to go 25000 steps stop and go another 25000 stop etc etc.
I would like for it to have a smooth motion (no stopping) say for 100000 steps.
Does anyone have idea how I can do this by modifying the following script.
Thanks
Gerry
// The following is a simple stepper motor control procedures
define EN 8 // stepper motor enable , active low
define X_DIR 5 // X -axis stepper motor direction control
define X_STP 2 // x -axis stepper control
define Y_DIR 6 // y -axis stepper motor direction control
define Y_STP 3 // y -axis stepper control
#ifndef limits_h
#define limits_h
// initialize the limits module
void limits_init();
// perform the homing cycle
void limits_go_home();
#endif
/// / Function : step . function: to control the direction of the stepper motor , the number of steps .
/// / Parameters : dir direction control , dirPin corresponding stepper motor DIR pin , stepperPin corresponding stepper motor " step " pin , Step number of step of no return value.
int N = 20;
int delayUs = 400;
int steps = 25000;
void step (boolean dir, byte dirPin, byte stepperPin, int steps)
digitalWrite (dirPin, dir);
delay (250);
for (int i = 0; i < steps; i ++)
digitalWrite (stepperPin, HIGH);
delayMicroseconds (delayUs);
digitalWrite (stepperPin, LOW);
void setup () { // The stepper motor used in the IO pin is set to output
pinMode (X_DIR, OUTPUT);
pinMode (X_STP, OUTPUT);
pinMode (Y_DIR, OUTPUT);
pinMode (Y_STP, OUTPUT);
pinMode (EN, OUTPUT);
digitalWrite (EN, LOW);
Serial.println(“Start1”);
Serial.println(“Start”);
void loop () {
Serial.println(“reverse-” + String(N));
step (false, X_DIR, X_STP, steps); // X axis motor reverse 1 ring, the 200 step is a circle.
Serial.println(“forward-” + String(2));
step (true, X_DIR, X_STP, steps); // X axis motor forward 1 laps, the 200 step is a circle.
N++;
