Can't getting graph on thingspeak
hello,
i am making project on " IOT based Air Quality monitoring " i have does the connections and uploaded code to my arduino serial monitor showing all the things like wifi connected, tcp connection established at port 80. and air quality is =“some digits” PPM. wifi is actually connectiong to my hotspot but can’t getting graph on thingspeak. please give me solution. (connections and code is here)
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(13, 12, 6, 5, 4, 3); // LCD connections
D13 ==> RS
GND ==> R/W
D12 ==> Enable
D6 ==> DB4
D5 ==> DB5
D4 ==> DB6
D3 ==> DB7
float t=0;
char data = 0;
String apiKey = “O0EOLL7LEI6H0UF2”; // Write API key
// connect 10 to TX of Serial USB
// connect 11 to RX of serial USB
SoftwareSerial ser(10,11); // RX, TX
// enable debug serial
Serial.begin(9600); // serial data transmission at Baudrate of 9600
// enable software serial
ser.begin(9600);
lcd.begin(16, 2); // to intialize LCD
lcd.setCursor(0,0);
lcd.print(" Welcome");
lcd.setCursor(0,1);
lcd.print(" To ");
delay(3000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" AIR");
lcd.setCursor(0,1);
lcd.print(“QUALITY MONITOR”);
delay(3000);
ser.println(“AT”); // Attenuation
ser.println(“AT+GMR”); // To view version info for ESP-01 output: 00160901 and ESP-12 output: 0018000902-AI03
ser.println(“AT+CWMODE=3”); // To determine WiFi mode
1 = Station mode (client)
2 = AP mode (host)
3 = AP + Station mode (ESP8266 has a dual mode)
ser.println(“AT+RST”); // To restart the module
delay(5000);
ser.println(“AT+CIPMUX=1”); // Enable multiple connections
0: Single connection
1: Multiple connections (MAX 4)
String cmd=“AT+CWJAP=“SSID”,“PASSWORD””; // connect to Wi-Fi
ser.println(cmd);
ser.println(“AT+CIFSR”); // Return or get the local IP address
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" WIFI");
lcd.setCursor(0,1);
lcd.print(" CONNECTED");
// the loop
t = analogRead(A0); // Read sensor value and stores in a variable t
Serial.print("Airquality = ");
Serial.println(t);
lcd.clear();
lcd.setCursor (0, 0);
lcd.print ("Air Qual: “);
lcd.print (t);
lcd.print (” PPM ");
lcd.setCursor (0,1);
if (t<=500)
lcd.print(“Fresh Air”);
Serial.print("Fresh Air ");
else if( t>=500 && t<=1000 )
lcd.print(“Poor Air”);
Serial.print(“Poor Air”);
else if (t>=1000 )
lcd.print(“Very Poor”);
Serial.print(“Very Poor”);
//lcd.scrollDisplayLeft();
delay(10000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" SENDING DATA");
lcd.setCursor(0,1);
lcd.print(" TO CLOUD");
esp_8266();
void esp_8266()
// TCP connection AT+CIPSTART=4,“TCP”,“184.106.153.149”,80
String cmd = “AT+CIPSTART=4,“TCP”,”"; // Establish TCP connection
AT+CIPSTART=id,type,addr,port
id: 0-4, id of connection
type: String, “TCP” or “UDP”
addr: String, remote IP
port: String, remote port
cmd += “184.106.153.149”; // api.thingspeak.com
cmd += “”,80";
ser.println(cmd);
Serial.println(cmd);
if(ser.find(“Error”))
Serial.println(“AT+CIPSTART error”);
return;
String getStr = “GET /update?api_key=”; // API key
getStr += apiKey;
//getStr +="&field1=";
//getStr +=String(h);
getStr +=String(t);
getStr += “\r\n\r\n”;
// send data length
cmd = “AT+CIPSEND=4”; // Send data AT+CIPSEND=id,length
cmd += String(getStr.length());
ser.println(cmd);
ser.print(getStr);
Serial.println(getStr);
// thingspeak needs 16 sec delay between updates
delay(16000);
Sart by reading how touse theforum andby posting your code properly; http://forum.arduino.cc/index.php/topic,148850.0.html
You should also post what your program actually manages to do.
Are you able to get your graph printed by some other means e.g. from a PC or laptop?
Try taking things one step at a time e.g. how do you know you have managed to connect to 'thingspeak'. Does 'thingspeak' have any diagnostic or troubleshooting advice - if so follow it.
