Cant increase variable.... please help.
Please help... (i also tried calling the variable at the start of code before the startup.)
I am trying to get the variable i to increase every time motion is sensed. but when motion is sensed, i get this output:
Count: 0
Value: 1
Immediate: 1
Count: 0
Value: 0
My code is blow.
int motion = 2;//motion pin
int LED = 3;//led pin
  pinMode(LED, OUTPUT);
  pinMode(motion, INPUT);
  digitalWrite(LED, LOW);
  int i;
  int value = digitalRead(motion);
  Serial.print("\n\n\n Count: ");
  Serial.print(i);
  Serial.print("\n Value: ");
  Serial.print(value);
  if (value == HIGH)
    digitalWrite(LED, HIGH);
    delay(3000);
    int i = ++i;
  Serial.print("\n\n\n Immediate: ");
  Serial.print(i);
  delay(100);
  int i;
This declares a variable named i and sets the variable to a random starting value each time through loop(). Is that what you want ?
   int i = ++i;
This declares a different variable named i with a different scope to a random starting value then tries to increment it as part of the initialisation which is undefined behaviour
Make the first declaration of i
 static int i;
to preserve its values between executions of the loop() function and
   ++i;
where you want to increment the value of that variable
Hi micahr,
I recommend reading this tutorial
Arduino Programming Course
https://startingelectronics.org/software/arduino/learn-to-program-course/
It is easy to understand and a good mixture between writing about important concepts and get you going.
As I'm no longer a beginner I can't judge if this tutorial is really easy to understand. So I would love to read your opinion
about it.
best regards Stefan
