I've got some hardware (mega 2560) with 2 128x32 SSD1306 OLEDS and an MCP2515 CAN transceiver. They work separately, but not together. If I run the code as below, the screens will work, but if I uncomment the CAN initialization in the setup loop, the displays no longer respond. Thoughts?
In another project, with one screen communicating via I2C and the CAN transceiver communicating via SPI it works fine.
///// LIBRARIES /////
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
#include <SPI.h>
#include <mcp_can.h>
#include <FastLED.h>
#include <Adafruit_GPS.h>
///// DEFINE /////
//#define OLED_RESET 4 // OLED display reset pin
#define CAN0_CS 53 // CAN Bus Chip Select pin
#define CAN0_INT 18 // CAN Bus Interrupt pin
// GPS
#define GPSECHO false // do not send raw GPS data to serial monitor
// OLED Screen 1
#define SCREEN_W 128 // OLED display width, in pixels
#define SCREEN_H 32 // OLED display height, in pixels
#define MOSI 51 // SPI Master Out Pin
#define CLK 52 // SPI Clock Pin
#define OLED_DC_1 6
#define OLED_CS_1 5
#define OLED_RST_1 7
// OLED Screen 2
//#define SCREEN_W_2 128 // both screens are the same size, use only one width definition
//#define SCREEN_H_2 32 // both screens are the same size, use only one height definition
#define OLED_DC_2 28
#define OLED_CS_2 29
#define OLED_RST_2 26
// LED Tach
// How many leds in your strip?
#define NUM_LEDS 32 // how many warning leds
#define WARN_LEDS 6 // how many warning LEDS on each side of midpoint (shift LEDS included)
#define SHIFT_LEDS 2 // how many shift light LEDS on each side of midpoint
#define TACH_DATA_PIN 22 // which pin sends data to LED tachometer
///// INITIALIZE /////
MCP_CAN CAN0(CAN0_CS); // Set CS to pin 53
Adafruit_SSD1306 display1(SCREEN_W, SCREEN_H, MOSI, CLK, OLED_DC_1, OLED_RST_1, OLED_CS_1);
Adafruit_SSD1306 display2(SCREEN_W, SCREEN_H, MOSI, CLK, OLED_DC_2, OLED_RST_2, OLED_CS_2);
CRGB leds[NUM_LEDS];
Adafruit_GPS GPS(&Serial2); // set serial2 to GPS object
///// GLOBAL VARIABLES /////
int splashTime = 1500; //how long should the splash screens show?
//Engine Parameters for Display
float oilPrs = 25;
///// SETUP LOOP //////////////////////////////////////////////////////////////////
Serial.begin(115200); // open the serial port at 115200 bps:
// Initialize LED Tach
FastLED.addLeds<WS2812, TACH_DATA_PIN, GRB>(leds, NUM_LEDS);
// Initialize displays
display1.begin(SSD1306_SWITCHCAPVCC); // initialize with SPI
display2.begin(SSD1306_SWITCHCAPVCC); // initialize with SPI
dispSettings (&display1);
delay(2000);
// // Initialize MCP2515 running at 8MHz with a baudrate of 500kb/s and the masks and filters disabled.
// if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) == CAN_OK) Serial.println("MCP2515 Initialized Successfully!");
// else Serial.println("Error Initializing MCP2515...");
// // Set up CAN interrupt pin
// pinMode(CAN0_INT, INPUT);
// CAN0.setMode(MCP_NORMAL); // Change to normal mode to allow messages to be transmitted
dispOilPrs(&display1);
delay(2000);
delay(2000);
///// MAIN LOOP //////////////////////////////////////////////////////////////////
///// SCREEN DRAWING FUNCTIONS /////
void dispSettings (Adafruit_SSD1306 *display) {
display->setTextColor(WHITE);
display->clearDisplay(); //clear buffer
display->setTextSize(3); // text size
display->setCursor(0,4);
display->println("Settings");
display->display();
void dispOilPrs (Adafruit_SSD1306 *display) {
display->setTextSize(2); // text size
display->setCursor(1,1);
display->println("Oil");
display->setCursor(1,18);
display->println("Press");
display->setCursor(72,6);
display->println(oilPrs, 0);
display->display();
