Can't intall the drivers
Just bought Arduino; When following the instructions (https://www.arduino.cc/en/Guide/ArduinoLeonardoMicro) Windows can’t install drivers properly. Trying installing the drivers manually, pluging the Arduino multiple times… nothing helped.
Using:
  • Windows 7
  • Arduino Leonardo
Read through this first.
Arduino troubleshooting for beginners.doc (370 KB)
Have you both tried the drivers in the "Old Arduino Drivers" zip.
Goto
Program Files (x86) Open the Arduino folder Then open the drivers folder There is a ZIP file for older drivers (Leonardo was discontinued) Extract the whole "Old_Arduino_Drivers" folder
Now when you want to update drivers for the Leo point it at that directory.
Or just point it at the drivers folder and include sub folders...either works.
Still doesn't work :/
In which case start with the first attached document. and dont just skip through.
Doesn't work, again...
You honestly went through "every step" in there ?
every step from "code 10"..., because this is the only topic that match my problem
also, it seems like Windows doesn't see the board, even if it's connected or not
Clearly you skipped quite a lot.
That in mind Im out.
also, it seems like Windows don't see the board, even if it's connected or not
I updated the document slightly do you want to start and read more of it ? Or am I still going to waste my time ?
