Can't let HC-05 order HC-06 to do things
Hi, everyone, I recently tried using the HC-05, and the HC-06 Bluetooth mod to send messages between them. But I can just let them connect, I can't send any news. :disappointed_relieved:
This is my code:
master(HC-05)↓↓
#include <SoftwareSerial.h>
SoftwareSerial BT(10, 11);
char val;
  pinMode(9, OUTPUT);
  digitalWrite(9, HIGH);
  Serial.println("Enter AT commands:");
  BT.begin(38400);
  if (Serial. available())
    val = Serial.read();
    BT.print(val);
  if (BT.available())
    val = BT.read();
    Serial.print(val);
slave(HC-06)↓↓
char val;
  pinMode(9, OUTPUT);
  pinMode(12, OUTPUT);
  BT.begin(9600);
  if (BT.available())
    val = BT.read();
    if (val == '1')
      digitalWrite(12, HIGH);
      BT.println("LED ON");
    else if (val == '0')
      digitalWrite(12, LOW);
      BT.println("LED OFF");
Any suggestions for improvement? Thanks! :pray:
how did you configure the HC-05 and HC-06? have they been paired? is 38400 bauds what they use? (seems you have 38400 for one and 9600 for the other BTW)
They maybe had connected, and the HC-06 was constant light. But how to check that they had connected?
follow a tutorial on configuring them
The introduction is very detailed! Thank you!
I switched the HC-06 baud rate to 38400, and they look like can send messages. :thinking:
But currently, when I key "1" in HC-05, the HC-06 will print "⸮". :anger:
Master code:
String val;
  pinMode(9, OUTPUT);
  BT.begin(38400);
  if (Serial.available())
    val = Serial.readString();
    Serial.println(val);
    BT.print(val);
Slave code:
String val;
  pinMode(9, OUTPUT);
  BT.begin(38400);
  if (BT.available())
    val = BT.readString();
    Serial.print(val);
    if (val == '1')
Where was wrong?
modify your call to readString() into readStringUntil('\n')
change the comparison if (val == '1') into if (val.startsWith("1"))
can you confirm what Arduino you are using and how the modules are wired ?
You can try this: Connecting 2 Arduinos by Bluetooth using a HC-05 and a HC-06: Pair, Bind, and Link | Martyn Currey
Your code is for configuring your Bluetooth module's but your heading implies you want communication between two blueteeth. The game is not the same but you need to configure an HC-05 as master first. See the Martyn Currey website referred to above.
You must use 38400 for AT mode.
You do not need to change the baud rate for communications.
Baud rate applies only to comms between Bluetooth and Arduino, and must match. It has nothing to do with Bluetooth /Bluetooth communications, or what might be going on at the other end.
I use the UNO board.
HC-05
RX-->11
TX-->10
GND-->GND
VCC-->5V
HC-06
RX-->11
TX-->10
GND-->GND
VCC-->5V
Thank's your reply, I now knew it. :smiley:
I have changed some places, and then it can talk between two Bluetooth!
Master code:
String val;
  pinMode(9, OUTPUT);
BT.begin(9600);
    val = Serial.readStringUntil('\n');
    BT.print(val);
I changed 38400 to 9600 because I found out that the baud rate needs to be the same. :smiley:
BT.begin(9600);
Slave code:
String val;
  pinMode(9, OUTPUT);
  BT.begin(9600);
  if (BT.available())
    val = BT.readStringUntil('\n');
    Serial.print(val);
    else if (val.startsWith("0"))
I also change the baud rate in the slave code.
And here is my test:
If someone have a similar problem, you can try my code, and maybe it will work! :laughing:
Good, but your code above is redundant and or misleading. It might as well be
  Serial.println(" Hello, Bluetooth here!");
Oh, I forgot to change it to "Hello".Thank you for your point, now I had changed.:laughing:
Master code:
String val;
  pinMode(9, OUTPUT);
  BT.begin(9600);
  if (BT.available())
    Serial.print(val);
Master code:
String val;
  pinMode(9, OUTPUT);
  BT.begin(9600);
    BT.print(val);
