Cant load arduino IDE
I've just purchased an arduino duemilanove, i have installed the drivers and downloaded the latest ide 0021 (WINDOWS XP). when I load the arduino ide an error message appears saying - launch4j error -
An error occured while starting the application.
Has anybody seen this before, I can't get the IDE to load, does the arduino need to be plugged in to load? I have it plugged in.
Yeah re-downloading and installing the IDE sorted it for someone else.
Could be some other program you have interfering with it perhaps.
Mowcius
Actually downloaded version 0020, and its working now, I also removed a bluetooth serial port that was disabled, just in case as seen there may be conflicts. I also removed all the drivers on the device and reinstalled individually.
Will retry 0021 once I run few examples and try with it again. Cheers mowcius
Well it was only very very minor changes from 0020 to 0021 so it should work if 0020 now works...
Mowcius
